Hi, I have a dell latitude D600 the power connector it was loose I resolder the power connector on the mother board however 3 Resistor got burn do to the false connections on powet jack I can identify the position # (RV2) (RV3) (R30) Can you please help to know The specific resistance on them Any advise will be wellcome I am an electronic tech. So like wise any question I can help just ask ? Thanks.....Tech.One
D600 wont power up
Try removing the battery and boot on the power cord sometimes the battery shorts the system so it will not boot if it does boot then you need to replace the battery it could be the battery is dead and your power cord is bad check and make sure that is not the case if the power cord is good then I would look into replacing the mother board you can find a replacement on Ebay or at dell .if you have to replace it do a google search on hot to replace the mother board on a Dell latitude D600
and you will ba able to get step by step on how to disassemble it
Aug 28, 2011 | Dell Latitude D600 Notebook
My dell d600 laptop cannot charge it only shows ac power on the screen but not showing charging sign and also it dosent charge the battery also.
its a issue with the mother board,, your not the only one!!!
I have 2 d600 with the same problem!! i tryed a new bat and new cord,, no help,, its the mother board,,, $50-$60 on ebay...IF YOU Find the right tech it should be no more then $160 to fix
Jun 30, 2010 | Dell Latitude D600 Notebook
Latitude D600 PC Notebook: dell d600 three light on and of problam...
This is do to the jack were the power button board plugs into the motherboard, i see this alot on d600 and d610, the lights come on for about 3 sec then computer turns off..
this can be fixed by resoldering the plug to the motherboard but most will say you need a new mother board the leads are small and tight together..
Used motherboard on ebay $60-150
May 17, 2010 | Dell Latitude D600 Notebook
Dell d600 power cord turns off when I plug it into laptop. I tried another power cord and had the same result.
Hi Boss it is the problem of your laptop mother board. replace it it will give you the solution
Dec 10, 2009 | Dell Latitude D600 Notebook
Dell latitude d600, mic works sometimes
The Mic is on the same board that the power button is on.. there is a problem with this board,, the problem is were the power button board plugs into the main board....... when you push down on the power button your affecting the mic''s conection to the main board,, {Its a bad plug}
The Mic is found next to the power button.. to the left look for a small pinhole,, ....try pushing down to the right side of that.. test Mic when you do this,,,
You need a new main [mother] board to fix
Sep 25, 2009 | Dell Latitude D600 Notebook
Find someone to remove mother board from laptop . latitude D600. I think the solder connection to the ac plug is weak or cracked.or getting loose.
Here are step by step instructions on how to remove the motherboard from a latitude D600: http://support.dell.com/support/edocs/systems/latd600/sm/sysboard.htm#1000473
The instructions seem easy to follow, but let me know if you need any more assistance with this.
Serge
Apr 09, 2009 | Dell Latitude D600 Notebook
My latitude d600 will not start.
Is the connection on the Laptop loose? Most power connectors are soldered onto the motherboard and are notorious for becoming loose. If the connector is loose you it may be shorting out the adapter. I would have a professional look at it before plugging the adapter back into it. If you are shorting out the adapter it could present a fire hazard. Most laptop repair companies will resolder the connector for around a $100.
Jan 27, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
David Payne
David Payne
