Question about Canon Pixma MP280 Photo ALL-IN-ONE Inkjet Printer, COPY/PRINT/SCAN
Duplex printing for Canon MP280
It was okay all the while, but since i updated my windows 8, the duplex printing became duplex printing (manual) instead. I have to select pages to print on each page, it will not print automatically anymore.
SOURCE: MP610 How do I duplex
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Posted on Nov 29, 2008
hquiteculo
  • 19 Answers
SOURCE: Duplex printing problem
do you have to replese driver of printer for IR6000
Posted on Feb 10, 2009
SOURCE: Canon MP610 Printer When automatic duplex
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Posted on Feb 11, 2009
  • 60 Answers
SOURCE: Duplex printing flips page
That should be a setting somewhere in the printer or the print driver on the computer.
Here's a link to the manuals that comes with it.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=16279#DownloadDetailAct
Posted on Apr 06, 2009
  • 127 Answers
SOURCE: Mottled effect on one face during duplex printing
that would b the fuser if it has build up on the rollers.. definitely change out the magenta toner and verify that the paper stock is within specs!
Posted on Mar 31, 2010
On the Ip4300 the yellow light flashes at 10 times intervals. The printer does not responde to anything. Thanks Dave
This is from Canon's web site...
Ten flashes:The Cassette is not installed properly/Cannot perform duplex printing
  • When loading from the Cassette, install the Cassette properly and press the RESUME/CANCEL button.
  • When performing automatic duplex printing, the size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A3, Regal, 11" x 17" (Tabloid), B4, A4, Letter, 10" x 12", 8" x 10", B5, and A5". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed.
May 04, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
How could i do manual duplex printing on my canon lbp 2900b
manual duplex printing is simple one
print one side and then place the printed paper in tray
and then print another print on another side
very simple
Aug 12, 2010 | Canon LASER SHOT LBP-2900 Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Epson C1100 Aculaser Duplex unit not recognised by Vista
I have had the problem, but it is easily fixed in Vista.
1. Click Control Panel
2 Click Printers
3 Right click your AL-C1100
4 Click Properties
5 Click Optional Settings label
6 Click - "Update printer info manually"
7 Click - "Duplex Print Unit "
8 Click Settings
9 Tick box in bottom left hand corner - "Duplex Print Unit"
10 Click OK .... exit
Sep 12, 2008 | Epson Aculaser C1100 Printer
Stopped duplex printing when updated to Vista
Check for new drivers(for your printer) or upgrade, for windows vista....Sometime the driver for windows xp is not the same.
Mar 25, 2008 | Lexmark E120n Laser Printer
Unable to duplex
Make sure that duplex printing is enabled in the drivers when you print. It should work. You might have to manually tick that option and it might not be enabled by default.
Dec 14, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Duplex printing won't work
There is no duplex on this printer, two sided printing is only achieved via manual feeding, I checked the canon website spec for the MP460
Oct 09, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canon Pixma MP280 Photo ALL-IN-ONE Inkjet Printer, COPY/PRINT/SCAN Logo
49 people viewed this question
old marine
old marine
