Question about Sharper Image Evsi-XS01 Air Purifier, Electrostatic Cleaner
How do i clean and remove the filter - Sharper Image Evsi-XS01 Air Purifier, Electrostatic Cleaner
How do I disaasemble the unit to clean the filter inside
There is no filter inside the unit. It's on the back of the unit. Once you remove it, you'll have access to the inside of the air purifier. I think what you wanted to know is, how to clean the plaques inside. Once the filter is removed, you'll see the plaques and they just slide out of their individual holder(s).
Apr 05, 2011 | Ecoquest Fresh Air Air Purifier
Will the Breeze AT help with the house hold dust kicked up by 2 St. Bernards etc. Also, can I clean the filter myself?
It should help to reduce the amount of air borne dust in your home. The filter can be cleaned either by vacuuming the lint screen or removing it and washing it with hot water and using a toothbrush to remove any dust buildup. Clean the purification plate with a 50/50 solution of water and amonia and a toothbrust to clean the grids. Allow both to dry completely before reinstalling. Make sure that the lint filter has the clip depressing the safety switch when reinstalling it. Hope this helps you.
Oct 27, 2010 | Ecoquest Breeze AT Living Air Purifier
I want to take my ecoquest fresh air apart to clean it, but do not know how, i have misplaced the manual
Unplug the machine and unscrew the phillips head screw on the back grill of the machine, that is just above the plug. There are depressions on the sides of the back grill that has a plastic tang that hold the back grill to the machine. Press the back grill inwards to allow the tangs to clear the sidee and the back grill should now be easily removed. Remove the two thumb screws on the top corners to remove the filter. Once the filter is removed, then you can remove the purification plate and remove the two screws that hold the RCI cell. The RCI cell and filter can be cleaned by vacumming out the dust and dirt.
The purification plate can be cleaned with a old toothbrush and a water and amonia solution. Scrub the metal grid with the toothbrush. Do both sides and then rinse with water, allow it to dry completely before reinstalling the plate. After every part is cleaned reassemble the purifier, and plug it in. Then press the reset reminder button on the front of the keypad to clear the "perform cleaning" message. This message will appear again after the purifier runs for 30 days to remind you to clean the purifier. Hope this helps you.
Oct 09, 2010 | Ecoquest Fresh Air Air Purifier
How remove and clean filters from Brookstone pure ion uv air purifier?
how to remove and clean filters for the Pureion UV air purifier?
May 21, 2010 | Brookstone Pure-Ion UV Air Purifier
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
Removing Filter from Back of EcoQuest Air Filter
You have to remove the two top screws to take off the filter (lint screen). At least they put in hand-tightening screws in the later models. Make sure you also alcohol-clean the needle ionizer in the front and the radio-wave (round) one on the side! It's crucial to keep the "FAST" dust clearing capabilities!
Sep 21, 2009 | Ecoquest Fresh Air Air Purifier
How do I clean the metal screen? Do I need to replace any filters at any point?
if the metal screen is removable, run under warm water and gently brush with damp rag
if no removable, unplug unit, wipe clean with damp rag
May 29, 2009 | Ecoquest Flair Air Purifier
Honeywell HFD-135 -- lost instructions -- how do i clean removable filter?
Manual can be found here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=47a366c04a65e77c69850893b979e142
Sep 10, 2008 | Kaz Honeywell QuietClean HFD-135 Air...
Cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Sharper Image Evsi-XS01 Air Purifier, Electrostatic Cleaner Logo
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
