Question about Sharper Image Evsi-XS01 Air Purifier, Electrostatic Cleaner
Clean and replace air filter for electrostatic air cleaner
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: I have an Ionic Breeze
Hi.
Parts for this unit, including the filter are not on sale anymore, as all Ionic Breeze models had been retired from commerce because of health and safety concerns.
No company will manufacture or distribute parts for this kind of Air Purifier. The units had been retired from commerce.
Sharper Image had been closed down because of the concerns linked to ionic breezer purifier.
Spare parts are not manufactured or distributed anymore.
Ionic Breeze Suit Drives Sharper Image into Bankruptcy.
Sharper Image Closing All Stores
Someone purchased SI name and reopened the company. The company is distributing new lines of small appliances, but they do not manufacture or provide support for their original appliances.
SI successfully distribute and manufacture only new products that are not linked to any health concern.
So repairing it is almost an impossible task except you want to take it to any electronic repairer around you to give it a trial...
Posted on Aug 19, 2010
Fan on air cleaner blows out top but does not suck
If air is blowing out - it most assuredly is getting in. The area of the intake make be large enough for you to perceive air being sucked in.
Make sure ALL filters are clean. Remove and replace disposable filters or wash and replace permanent filters. Do this for pre-filters too. Then, try again.
Oct 23, 2015 | Hunter 30200 Air Cleaner Purifier Filter...
I cleaned purifier plate and filters and purifier still won't workon my fresh air machine
The air purifier filters which need to be washed lose their efficiency very fast and need replacement every few months . I think its time you switched to a better air purifier like this with superior filters which last longer and can be cleaned using a vacuum cleaner Premium Air Purifiers with e2f technology
Oct 22, 2014 | Air Purifiers
It keeps making a static sound. and it lights up with the sound because there is a small shock that happens ever 10 seconds in the back above the filter
That happens when the electrostatic grid needs to be cleaned. There should be instruction for cleaning the electrostatic grid in the owner's manual.
Nov 05, 2013 | Air Purifiers
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
My electrostatic air purifier cracks and pops even when the filter is clean. What is the problem?
If it's only doing it for a short period of time, it's picking up dust in the air and zapping it like a bug zapper. If it's continually doing it, there may be a short where the filter touches the electrodes or just misplacement of the filter.
Mar 19, 2011 | Kenmore Air Purifiers
My Oreck air filter makes a snapping sound every 5-10 minutes. I have cleaned it thoroughly and checked for wires but I can't see anything wrong. I even switched the air filters thinking that one room was...
Dont use when it does this. Your collection grate is dirty and the sound you hear is an electrical discharge arcing between the grates like a small bolt of lightning. That entire metal electrostatic grate needs to be cleaned with Orek's cleaner or something similar. But certainly do not use until you fix it.
Jan 11, 2011 | Oreck (AIRCOM1WOI) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Is this a good model # for a GE electrostatic air cleaner/filter. If so, are parts still available for it? Model #BEF28009 (I.D. tag is hard to read?)
not likely the electrostatic air cleaners are discontinued for the most part because the really didnt do all they claimed. you can achieve much better air quality from a standard media air filter with a merv rating of 10 or better.
Sep 11, 2009 | GE Air Purifiers
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
Ionic Breeze Quadra Electrostatic Air Cleaner, Model S1637
http://www.allergybegone.com/ionbreezquad1.html
There is a manual for your purifier at this website.
It is in pdf form, free to download.
look for the sentence on the page.
it will take you to the download.
Feb 25, 2008 | Air Purifiers
Sharper Image Evsi-XS01 Air Purifier, Electrostatic Cleaner Logo
44 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
