Question about GE JTP20 Electric Single Oven
Beeping with Code F7 E6
Beeping wanting me to turn on the over and the broil HI is flashing. BUT I did not turn the oven on. Cannot get it stop beeping but for a few seconds then have to hit stop again.
CMV9
  • 594 Answers
SOURCE: GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Posted on Aug 19, 2008
aborcass
  • 2651 Answers
SOURCE: f7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Posted on Nov 17, 2008
  • 234 Answers
SOURCE: Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Posted on Jun 24, 2009
  • 3230 Answers
SOURCE: the F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
Posted on Jul 28, 2009
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
Oven is beeping flashes f7. goes from push start for hi broil to low broil
HI, your key pad or touch pad is malfunctioning. most units will have a integrated touch pad. In this case, you will need to replace the entire control board, in order to restore normal functions. Now, if you units control and key pad are separate entity's, i recommend this test below to determine which is at fault.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 21, 2009 | GE Ovens
Ge oven JTP15 beeping and flashine F7 error
Jun 17, 2009 | GE JTP15 Electric Single Oven
Apr 27, 2009 | GE Ovens
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Mar 29, 2009 | GE JKS05 Electric Single Oven
Beeping and F7 when cleaning
F7 stuck keypad
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
F7 error steady beeping
Nov 17, 2008 | GE JKP45 Electric Double Oven
Beeping wouldn't stop, now it's dead.
F7 means you relay board is bad, you need to replace it.
Jul 23, 2008 | Dacor ECS130 Epicure Electric Single Oven
F7 Code
Try the fix at  http://www.fixya.com/howto/h155060-dreaded_f7_error
worked for me.
Jul 08, 2008 | GE Profile JTP18 Electric Single Oven
GE JTP20 Electric Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
