Question about Blu Cell Phones
Phone will not charge
I have been trying to charge for hours and phone is not charging
  • 9 Answers
SOURCE: how much time to we have to charge Samsung Omnia phone
Depends on your firmware. Updating your firmware on the somsaung site will prolong your battery life. Mine used to last about 2hours with heavy repative use. Music, gps, video etc. Standby would last about a day and a half with a few calls. Now it lasts about 4-5hours with heavy use and standby up to about 4 days with calls here and there.
Posted on Mar 26, 2009
GrinningFool
  • 625 Answers
SOURCE: BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
Posted on Jul 05, 2009
firesnake09
  • 2923 Answers
SOURCE: will not charge
It could be that the battery is bad. Bring your phone in to any repair shop and try using another battery. Most cellphone shops or stores has a test battery.
If you couldn't find a test battery, refer to a cellphone tech to test if the battery is still okay.
Posted on Jul 28, 2009
jacko0
  • 159 Answers
SOURCE: iphone shuts down automatically
Try this
http://jacko0.wordpress.com/2009/12/19/how-to-reset-an-unresponsive-iphone-and-get-it-working-again/
Posted on Jan 10, 2010
  • 85 Answers
SOURCE: phone wont stay charged
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/c905?cc=ie&lc=en
go to this link and download this software...its and update for ur mobile phone...i am 99 % sure that this will help
Posted on Aug 23, 2010
My phone will not charge. I can connect it to the charger and it looks like it is charging. Remove the charger then phone goes off. I charged the battery with a stand alone charger then installed battery....
It maybe a problem on the phone already and not on the battery. Something inside the power ic / board that's why any battery will not hold charge for long. Try also draining the battery and then charging it for a full 2 hours with the phone powered off as this charges the phone faster.
Mar 07, 2011 | Motorola Mobility MOTORAZR2 V9 Cellular...
My phone ran out of power overnight - when i attached recharger the phone sprang to life in emergency mode - it's been charging over an hour but still in emergency mode and i can't power down, the buttons...
Try taking the phone battery out of the phone,then leave the phone for 15 minutes replace battery and plug inlead for charging don't turn on the phone but charge the phone for a couple of hours then turn on and see if it has been fixed.
Steve B
Feb 01, 2011 | LG GT540 Cell Phone
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Battery power is very weak
    1. Try this first  power off your cell phone and charge it for 6 hours
    2. remove the charger and power on your cell phone start using it
    3. please note that don't use your phone while charging unplug it if you need to use
    4. only recharge it when it shows battery is low
    5.  please buy and use original battery and  charge
    6. I am sure that you can see the difference
    Jun 20, 2010 | Nokia 6500 Slide Cellular Phone
    K550i charging problem
    in sony k550i mobile phone battery will not charge through monile charger i will check the charger but it is ok. when charger is connect to mobile then show on charging box make a charge but achually charging is dcressing.
    Oct 17, 2009 | Sony Ericsson K550i Cellular Phone
    Nokia 6300 Switching off
    Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
    Jul 25, 2009 | Nokia 6300 Cellular Phone
    Battery not holding a charge.do you leave phone on while charging
    firstly the battery from new will need charging for about 8 hours to boost it after that it should reach full charge in about 1 hour it will charge if it is on or off and when off should show a charging bar how ever there is no way it will recognise when fully charged so dont leave over night otherwise it will reduce battery life greatly
    Jan 12, 2009 | Dual Electronics CECT P168 Cellular Phone
    Battery charge question
    in this phone when the battery is fully charged the running battery indicators stop at full position. U must charge every phones battery a maximum of 2 hours b'coz charging more than it reduces battery life and if the battery is not fully charged in 2 hours u must charge it after 20 minutes again
    May 20, 2008 | Nokia 2610 Cellular Phone
    Batteries draining problem?
    this problem can be caused by many factors. Use of the phone can drain battery life for example if you use the phone for browsing the web or as an mp3 player, even to make or recieve calls the battery life will not be as long as it would if just on standby. also if the battery hasn't been conditioned or is being over charged this can also lead to short battery life.To resolve the problem try conditioning th battery, basically let the charge drain completely out of the phone until the phone actually switches off, then charge the phone for 24 hours. Next time the battery goes ded only charge for the recommended charging time (this info can be found either in your phone user guide or by contacting the customer service department of your network provider).
    Mar 30, 2008 | Samsung SGH-d807 Cellular Phone
    "searching" message even when handset on the base
    Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
    Jun 03, 2006 | AT&T 2256 Cordless Phone
    Cell Phones Logo
    15 people viewed this question
    Top Blu Cell Phones Experts
    Lawrence Oravetz
    Dakshinamurthy...
    Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
