Question about Robot Coupe R2U Ultra Food Processor
Fix robocoup press go button motor hums does not spin
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me
screaming_skull@hotmail.com Cheers Ross
Apr 03, 2015 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Kenmore garbage dispsal that made humming noise for like 3 seconds then completly shut down. it's not the power. could the motor be burned out? i already checked the wiring.
Hi there: hate to say but it sounds like the Garb D.'s motor has failed. Perhaps due to a jam up in the blades. The motor will cook before the circuit breaker if the breaker it is on is greater than 15amp. Solution... Turn the power off and try to turn the grinding impeller blades.. If they spin freely on first attempt, which I doubt they will, then the motor is K-put. Hopefully it has a built in thermal trip and will reset itself. But while you have the power is off, clean it out. If you do that and it hums only, you will need to replace motor. sorry
ash
Sep 24, 2010 | Kenmore Food Processors
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DFP-14BC Custom Food Processor
My food processor turn on button won't work.
-Tha Mp3 Doctor
Nov 25, 2008 | Cuisinart DLC-5 Food Processor
Makes humming sound motor will not spin
Did you replace the start capacitor or start relay first ? This is the most common problem & a hell of alot cheaper than a new motor. Did you replace the motor shaft seal (around the shaft on top of the unit ? if not you will be replacing the motor sooner than you need to because the acids from veggies eat these things up & is the main reason why the motors fail, next in line is overloading or forcing product.
Sep 15, 2008 | Robot Coupe Blixer BX6 Food Processor
The cuisinart food processor doesn't work.
-Tha Mp3 Doctor
Aug 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Lights all Come on, Then spins up a few seconds then dies
Remove work bowl completely - then try the various buttons. If no spinning occurs with work bowl removed, the motor is dead. Find out from Cuisinart if you are still under warranty, and send in for repair.
Jun 08, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Robot Coupe R2U Ultra Food Processor Logo
Top Robot Coupe Food Processors Experts
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
