Question about Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000
Blower fuse Where I can find this type a fuse. Would another type would work?
How do you remove a multi fuse, that runs the heater blower. on engine panel?
One type of these fuses simply pull out of the socket the other type bolts the fuse blades to the contact in the fuse panel. To determine which one you have just try to pull the fuse out without using excessive force.
Feb 19, 2015 | 2011 Kia Sorento
Why does my s type air con blower not come on at all?
check your blower connection.
Check the fan relay.
Check you fuse block
Apr 29, 2014 | 2004 Jaguar S Type
Heater blower dosnot work
what type of car are we working on. might be the blower motor resistor, usely close to the blower motor. not enough info to help ya much.maybe the blower motor it self failed?
Dec 02, 2012 | Cars & Trucks
Type your problem for a solution..HEAT NOT BLOWING FUSE OK.
REMOVE HEATER BLOWER MOTOR AND HOT WIRE IT.IF HEATER BLOWER MOTOR WORKS WHEN HOT WIRED EITHER BLOWER RELAY BAD OR AC AND HEATER CONTROL SWITCH NOT WORKING.IF BLOWER DONT WORK WHEN HOT WIRED BLOWER MOTOR IS BAD.
Oct 25, 2011 | 1997 Nissan Quest
Heater AC blower not working
Possible that the fuse to the blower- marked as Blower/fan- can be open or blown. If so replace with the same type, however if the fuse is intact the blower /fan switch or the fan itself can be faulty.
You need to check the voltage at the fan unit to confirm- use a multimeter to test.
Jun 13, 2011 | 2006 Pontiac G6
My heater dont work in my 2020 s type 4.0 and tring to locate fuse box
i think that fuse your looking for is under the hood near the AC/heater box its located in one of the wires going to the heater
Jan 22, 2010 | 2002 Jaguar X-Type
A/c , heater blower not working but a/c & heater are working
No fuse. Newer vehicles have BCM Body Control Modules. Everything is computer controlled. Take it to a shop.
Sep 27, 2009 | 2004 Ford F150
Fan only works on 4 and 5 settings? Is this a
I have a 2003 Chevy Cavalier. The HVAC airflow dial only works on high setting. We checked the fuse and it's o.k.
What now?  Any estimate as to repair cost?
Thank you
Sep 07, 2009 | Chevrolet Malibu Cars & Trucks
Pug 205 1987 Blower not Blowing
IT COULD BE BLOWER MOTOR NOT GROUNDED.YOUR BLOWER MOTOR FUSE AND RELAY COULD BE BAD.MAKE SURE POWER IS GOING TO BLOWER.MOTOR.CHECK TO SEE IF POWER IS GOING TO SWITCH IF SO SWITCH COULD BE BAD.HOT WIRE BLOWER MOTOR USING JUMPER WIRE AND POWER FROM THE BATTERY.IF BLOWER MOTOR WORKS.YOU HAVE FUSE RELAY AND SWITCH PROBLEM.MOST THE TIME WHEN RESISTOR BAD.YOUR BLOWER MOTOR ONLY WORK ONE SPEED SOME TIME.
Sep 03, 2009 | 1989 Peugeot 405
Intermittent windscreen wipers not working
I have solved the problem of the intermittent windscreen wipers not working. It did turn out to be the relay (R1 - engine compartment fuse box). As the main wipers continued to work it seemed unlikely to be this relay. However the relay has a number of connections and different wiper operations use these different connections. I discovered the solution by using relay R19 (heater blower) as this is the same type. It can be found in the passenger compartment fuse box. It worked. Also the blower still works with the old wiper relay as it seems to use only the same part of the relay as the main wipers did. However, I will replace this one just to be on the safe side. Hope this is useful.
Aug 12, 2008 | 2002 Jaguar X-Type
Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000 Logo
62 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
