Stevie farmer hudl - Computers & Internet
How do I transfer photos from my computer to my Hudl 2?
Hi. To transfer your photos from your computer to your Hudl 2, connect you charging cable to your computer. Make sure that your Hudl 2 is show under the 'My Computer' page of your folder section. Then select your phots and drag the into the Photos folder of you Hudl 2. This can be found by double tapping the Hudl 2 icon on your pc.
I hope this helped.
Aug 23, 2015 | Tablets & eReaders
How can I get of the tutorial menu.it seems to have frozen
According to Salivat Gairdner, below is How to un-freeze your hudl.
Turn over your hudl and search for a hole. Once you've found it, find a pen or pin and push it in. The hudl's screen should turn off. Turn the hudl back on using the power button and your set!
How to fix the freezing bug
Tesco has released an update which includes a setting in the Display section. It should automatically install, if it doesn't go to Settings then to About Tablet. Click on System Updates and wait for the hudl to find the update, if it does find one - leave it be until the installation has finished. Once it's finished, go back to Settings then to Display. Click on Reset touch screen, this is what causes the hudl to freeze. Click on Reset screen and your done!
Apr 26, 2015 | Computers & Internet
Where is the the recharging button om my hudl 1
Hi Robert,
You should just be able to plug your HUDL in and it should begin charging. Check that the outlet you're using is providing power (try another outlet too).
I'd recommend getting in touch with Hudl directly should you need additional support, I've included their support page below:
Get the Support You Need
Hope this helps!
Feb 27, 2015 | Computers & Internet
How do I import contacts to hudl from my PC
Almost all email or data base contacts can be exported as comma delineated text files Are you able to do that kind of thing? If not I can not give you good step by step without knowing from what OS and application you are exporting the data from. Then I would need to know what version of OS is in that hudl.
Oct 26, 2014 | Tablets & eReaders
HOW DO I CONNECT MY HUDL FOR EMAILS
Verify the Hudl criteria for passwords. You may be using - for example - a ? in a 15 character PW, and Hudl only allows 8 character PW's and will not permit the use of the character "?". See where I'm going here? I have about 7 websites that have specif criteria that will not let me generate my typical 15-19 full character set PW's, so I modify the PW to meet their needs. We both win.
Sep 20, 2014 | Computers & Internet
How do i turn off talkback on my hudl
are you talking about hudl for video playback.. like sports teams use.
Aug 14, 2014 | Radio Communications
How to print on hudl
hudl does not have printer drivers, you need to transfer the files to a pc or mac that can print them.
Jun 08, 2014 | Computers & Internet
Hudl recovery system v4.2.41
Try holding power button until tablet goes off then press and hold power button and volume up when screen lights up release both then press power button and then volume up to get reboot screen delete factory data then press on reboot now.
Read more: Problems with hudl booting up stuck on s reen just before home screen? - Tablet not booting up press reset button and retried and still the same :: Ask Me Fast at http://www.askmefast.com/Problems_with_hudl_booting_up_stuck_on_s_reen_just_before_home_screen-qna7654743.html#q5717985
or
The Hudl can be restarted by putting a pin in the tiny hole on the back of the Hudl. Did this and it sorted the "recovery systme v4.2.41" no start problem.
Mar 10, 2014 | Computers & Internet
Low sound volume using with hudl
perhaps you have the speakers connected to the wrong connector on the hudl
Feb 28, 2014 | Labtec Audio Players & Recorders
In a village 100 acres of land was distributed among 10 farmers. The farmers were very happy because all of them got equal-sized plot of land. How did the head of the Panchayat manage to do this?
The head of panchayat must have provided each farmer with a land of size 10 acres which will be equal for all the farmers and the total land is also consumed.
this can be found out by dividing the total land by the number of farmers
i.e (100acres/10)= 10 acres for each farmer
Oct 02, 2010 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
