Question about Goodman GMS80903BNA Heater
Furnace stop running after a few mins
Shut the furnace off and restart the furnace running for awhile and stop.
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Furnace start stop cycle
On properly sized furnaces there are a few controls to look at. Check the settings of the fan switch. If these are unchanged then there may be a reason the furnace is shutting off due to poor air flow and resulting high temperature. Check filter and verify air flow is good. It may be possible that a safety switch is failing and intermittently on and off. Are all the covers securely in place and hitting any safety switches? If not seated properly the cover may loosen when the fan runs and the switch shut off the unit. There is often a flame roll out switch that could have been strained. Lastly, has the thermostat been working long? Thermostats have internal heaters to stop the furnace which is called a heating anticipator. If the thermostat is near a heat source (heat duct, refrigerator, oven, person, hot water pipe), worn out, anticipator is set wrong (older electric thermostats have adjustable settings) or covered (yes, I have seen some covered) then the free room air cannot measure correctly and the thermostat cannot control what it cannot accurately measure. Of all these possibilities I would start with the thermostat and proper furnace air flow, second check the fan/high limit switch and third go component by component through the wiring diagram looking for defects in each component. If available follow the manufacturer's troubleshooting guide.
Jan 11, 2014 | Rheem Heating & Cooling
Furnace kicks on and heats up for 5 min. then will shut down - no flame - main blower will run for a few min and then the whole cycle will start again. flame sensor checked ok with meter at approx 5.0
What is your temperature rise during the 5 minutes it does run? Could be overheating and kicking out on limit switch. Watch the diagnostic light for a code. (3 blinks means this, 4 blinks means that etc.)
Jan 09, 2014 | Amana Heating & Cooling
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
