Question about Exercise & Fitness
Weslo crosswalk 5.0t WLTL29310.0 display will not work and has no power
Put it together and reset the button and will not come on. then after a while hear like it wants to come on but it doesn't...
joboo1
  • 257 Answers
SOURCE: weslo pro tread belt
Hi, Yes it is! the belt is not free floating but travels on a slide. When there is pressure on it ( from someone) it rubs on the slide underneath. When you step off it should stop the rubbing noise. There you go, this should Fixya!
Posted on Mar 24, 2009
  • 42 Answers
SOURCE: i purchased a weslo pro
hi weslo treadmill keys are mostly the same, i have seen some on ebay selling for under £15.00. or if you contact icon health & fitness 08451770512, these people are the main suppliers of weslo treadmills and parts. they are uk leeds based.
Posted on Nov 21, 2010
  • 95 Answers
SOURCE: missing a key for Weslo
Here is a parts list for the Weslo Crosswalk 365e - scroll down to "Safety Key" and that is the part you need. They are pretty cheap so I recommend getting a couple extras in case you lose one again.
Posted on Mar 23, 2011
  • 1156 Answers
SOURCE: Jus put together brand new crosswalk RT 5.0
Thank you for posting your question on fixya. I will be happy to help you with this problem. Can you please give us some more information so I can better answer your questions.
Did you follow the instruction on the manual?
Ok,You can try the below steps..
Things You'll Need
* Allen wrench
* Phillips screwdriver
* Measuring tape
Power Doesn't Turn On
Plug the power cord into a single-outlet surge suppressor and plug the surge suppressor into a grounded outlet.
Check that the magnetic safety key is fully inserted into the 540S console.
Locate the circuit breaker on the front of the treadmill next to the power cord. Check if the circuit button is protruding out from its recess. If it is, wait five minutes then press the button to reset the breaker.
Display Isn't Working
Remove the safety key and unplug your Reebok Treadmills. Lift the end of the walking deck. Hold the deck with your right hand and pull the latch knob out with your left hand. Push the walking deck until the latch knob aligns with the hold in the left handrail. Release the latch knob, making sure it locks into place.
Lower the treadmill to the ground so you can access the area under the motor. Remove the two 3/4-inch screws on the bottom of the treadmill. These screws hold the motor hood in place.
Lift the treadmill back up to a standing position. Pull the latch knob out and lower the deck back to the ground. Gently pull the hood cover off.
Find the reed switch and magnet on the left side of the front pulley. Turn the pulley until the magnet lines up with the reed switch. Measure the gap between the reed switch and the magnet. The gap should be 1/8 inch. If not, loosen the screw above the reed switch and adjust the switch so the gap is 1/8 inch. Tighten the screw.
Replace the motor hood and the 3/4-inch screws that hold the hood in place.
Hope it helps.
Please keep me posted..
Posted on Sep 13, 2011
ercupa190
  • 12223 Answers
SOURCE: My weslo momentum 7.0 ex elliptical machine display stopped working. It won't power on even with new batteries.
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of the pedalsto the crank axles.
ernesto cuadramanagua, nicaragua
Posted on Mar 10, 2012
Weslo Cadence 340 power shut down while i was on it, tried the reset button and it actually fell inside, i took the front off and the reset button wont budge. Put the key in and I do have power, just...
If it doesn't have a fuse Only the reset button that is your over current protection, if it's broke the treadmill won't work tell it's repaired. ... hope this helps ?
Feb 24, 2015 | Weslo Cadence Treadmill 340CS
My weslo pro crosswalk 7.9 will not go all the way up or down
There are a couple of good DIY treadmill repair videos on youtube.
If this one doesn't address your issue, brouse around a little.
Jan 11, 2015 | Weslo Exercise & Fitness
The reset button is on reset, the elect outlet has electricity. Put the treatmill together according to booklet directions. Panel displays 0's but the start, stop, nor any of the numbers work....
adjust the reed swtich, see the diagram attached,clean it, and tight very well the connector
2) replace the batteries and clean the contacts battery very well.
God bless you
Nov 11, 2012 | Weslo Cadence G 5.9 Treadmill
Display does not work but incline keeps going up and down
1)If your display have batteries please change for a news ones.
2)adjust the sensor reed switch about 1/8" or 3mms aprox see diagram attached.
3)Use DMultimeter for to measure +5Vdc for I..C(EPROM,ROM,etc)
is coming from the board (Main Control Motor Board or lower board)
4)tight the connector (flexible cable) well to the lower board).
Remember about 90 percent from function of the treamill is coming from the lower board.
Now you will have a strong answer about the troubleshooting from your treadmill.
Nov 22, 2011 | Weslo Pro Crosswalk 7.8 Treadmill
Missing a key for Weslo treadmill crosswalk 365e- can you assist? I live in calgary Alberta
Mar 22, 2011 | Exercise & Fitness
I purchased a weslo pro crosswalk 7.8 it doesn`t have a safety key how do i know which key and where to get 1 thanks bill
Nov 20, 2010 | Weslo Pro Crosswalk 7.8 Treadmill
Buttons not working
there is a safety key (red magnet) needed to operate the treadmill; you can get that from the person responsible for the sports section.
Oct 07, 2009 | Weslo Pro Crosswalk 7.8 Treadmill
Weslo pro tread belt
Mar 24, 2009 | Weslo Pro Crosswalk 7.8 Treadmill
Exercise & Fitness Logo
37 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
