Question about Bosch KSV33622 Top Freezer Refrigerator
Can dako refirgeratores be use 110v or 220v - Bosch KSV33622 Top Freezer Refrigerator
2 Suggested Answers
  • 267 Answers
SOURCE: i bought a rotary hammer drill from Asia 220V/60Hz & I want to use this in Canada 110V/60Hz Can I use Step down transformerconverter available in amazon or ebay?
Yes you can.
Make sure the transformer is rated for more power than the drill label states so that you don't burn up the transformer if you stick the drill bit.
For instance, if the drill is rated for 5 amps at 230 volts you should get a 1500 watt transformer. 230 x 5= 1150 watts; the next common size up is 1500 watts. You don't want an 1200 watt if it is available.
Transformers are also rated in KVA [Killovolt-amps] so the same transformer would be 1.5 KVA.
Do the math for your drill and save future problems. If a transformer doesn't have a rating with real numbers, avoid it. There are lots of really cheap ones on the market that you will regret buying.
Posted on Feb 07, 2015
Will my 240v charger work on 110v
Can't say for certain, but there are specific 110V and 220V versions of DCB101.
None are labelled 90-220VAC as would be normal for universal voltage equipment.
If you operate 110V equipment on 220V then you will most likely damage it with overvoltage.
If you operate 220V equipment on 110V then you will most likely damage it in over current or have it simply not work.
It is possible that the charger is universal, just not labelled as such.
Send DeWalt an email.
Mar 29, 2015 | Dewalt 12v Max - 20v Max Li-ion Battery...
What is required to use it as far as electrical outlet.
Dryers come in both 110V and 220V.
If you plug a 220V dryer into a 110V socket, it will run very slow.
If you plug a 110V dryer into a 220V socket, it will burn up.
If you can find a 220V extension cord, then you should be able to use it.
Mar 08, 2015 | Dryers
I have a pro cut 25 i would like to change it from 110v to 220v
The pro cut 25 will run on ether 110v or 220v without changing anything. I made a 220v to 110v adapter. It works well and if I want to run it on 110v it will still plug right in.
Dec 05, 2013 | Lincoln Electric Plasma Cutter, Pro - Cut...
Makita Dc18rc from 110v to 220v
Did Someone Succeeded to Change the DC18RC from 110v to 220v ??
What are the component that should be replaced ??
Where can i get them ?
Thx ,
Lio
May 17, 2013 | Drills
My fan running 110v how to convert in 220v
Use a stepdown transformer to reduce the 220v back to 110v. You can buy them on the internet for using 110v gear in 220v countries
Apr 13, 2012 | Air Purifiers
Logitech z515 power US is 110V - israel is 220V - is US to EU plug adapter sufficient to use in Israel ?
No you cannot as 220v will damage the 110v the Logitech. You need a stepdown transformer to reduce the voltage from 220v to 110v. and then you can safely plug the Logitech into this stepdown transformer.
Jan 30, 2012 | Logitech Z515
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
110v or 220v ?
That would be a 220v dryer...virtually all electric dryers are 220v.
heatman101
Apr 19, 2010 | Maytag MDE2400A Electric Dryer
What is the specific power transformer (internal) i need to switch my logitech 230 speakers from 220v to 110v?
If the speakers are wanting 220V, will they work, at a diminished level, if you only supply 110V ?
Otherwise, you need a "step-up" transformer, which takes 110V input, and produces 220V as output.
Do the speakers have a "110V/220V" switch on them????
Apr 05, 2010 | Logitech X-230 Computer Speakers
Bosch KSV33622 Top Freezer Refrigerator Logo
16 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
