Question about Kenmore Washing Machines
Diagnostic codes and procedure for kenmore 41748102701 front loading washer
duby1990
  • 370 Answers
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
jyackle5
  • 8197 Answers
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Posted on Dec 18, 2008
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
  • 1294 Answers
SOURCE: washer won't drain
That is, in short: FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Posted on Mar 29, 2009
Krazytech
  • 725 Answers
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
What does 5d mean when it comes up on front load whirlpool duet
5d is: It denotes suds lock (overdose of detergent dectected during the wash cycle).
Chances are you just put too much detergent in, or maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore washer elite 44832200, error code h and f
The error codes aren't listed in the owner's manual.
Each one of these washers come with a technical data sheet inside. To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams.
Read through the information and let me know if you need assistance beyond what the tech sheet provides. I hope you find this information helpful.
May 09, 2010 | Kenmore Elite 45986 Front Load Washer
How do I put a Kenmore 417.44092500 into test mode
Each one of these washers comes with a technical datra sheet inside. The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. Some model washers have two versions of diagnostics that include SHORT and LONG step modes to include simple and more advanced troubleshooting procedures. Since the procedures for entering diagnostics differs between models, it is recommended that you refer to this tech sheet to ensure you perform the procedures correctly.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Apr 07, 2010 | Kenmore Energy Star 44092 Front Load...
Kenmore elite he3 model#110.42822201 washer; where can I get a schematic? Graham
Every one of these front loaders come with a technical data sheet inside. You need to remove the lower toe panel directly below the door to access it. The screws are located under the bottom front edge of the washer. You may have to prop the two front feet of the washer up to access them (a 2x4 works well for this). With the screws removed, the panel will drop down, then come off. The tech sheet will either be located directly behind the panel, or affixed to one of the interior cabinet walls in an envelope. The tech sheet includes all troubleshooting data, error code definitions, diagnostics procedures, test points and wiring diagrams. I hope this helps you.
Jan 30, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Error code EB3 Washer turns on but does not fill with water I have a Kenmore Front Load washer ran diagnostic test
eb3 = incomming line voltage below 90 volts
check voltage at outlet, if above 90 volts replace control board
would strongly recomend having a profesional look at it ... this should save both of you some time and money though.....
Oct 25, 2009 | Kenmore 46462 Front Load Washer
Whirlpool WFW9600T Washer - How do I run diagnostic mode?
Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
158 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
