Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I have epson tx125 and all the lights keeps on flashing and says general error?
  • 124 Answers
SOURCE: epson pituremate
try the following: 1. Turn printer off. 2. Disconnect printer from computer. 3. With printer turned off, hold down both the Paper and the cleaning buttons. 4. Continue to hold the buttons and turn the printer on. 5. When the Paper light starts to flash, release both buttons. 6. Immediately press the Cleaning button and hold it down for at least 10 seconds (until all the lights begin to flash and the printer will begin to reset). 7. When the Power light is steady, the printer should work. 8. Don't forget to clean out the waste ink tray and if necessary replace the waste ink pad. good luck
Posted on Mar 26, 2006
cene765
  • 787 Answers
SOURCE: GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
Posted on Oct 16, 2009
SOURCE: general error
hi mya printer heaving genral error problem is there any one who could help me
Posted on May 21, 2010
jay767
  • 386 Answers
SOURCE: i have epson tx110 and
This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
1. The print head is stuck somewhere or is unable to move because of some blockage in the printer's bay.
2. If you are using a Continuous Ink System, then the tubes might have blocked the print heads from moving.
To resolve, turn OFF your printer. Remove such blockage then turn the printer back ON.
Regards,
JR
Posted on Oct 06, 2010
murmerjoy
  • 805 Answers
SOURCE: General error and flash alternately
if paper jam then open the back case and wipe the dust from roller by using thinner. and check your runner belt. if everything ok then flash your printer by using the ss utility software. thanks
Posted on Oct 26, 2010
Epson R1900 cartridge carrier goes lef and grinds until it stops with flashing lights
It;s general error or fatal error. Find the Adjusment Program for R1900, then Click Printer Information Check. You will find the latest fatal Error code. You can figure the actual error of your printer.
Jan 17, 2013 | Epson R1900 Printer
My Compaq cannot recognise my Epson TX125 printer. It results in an error in the print Q. I had this on a sony some time ago and PC world fixed it by resetting a parameter on my computer. I was told that...
forget Sony this is not SONY at all its HP./MS and Epson. only.
lost the epson install disk/?
what OS> windows/ what ? XP
the CQ60 is very very old PC notebook.
and then getting the software from EPSON.
matching your OS and the manual to install it
is it USB connected, you never said.
direct or via external usb hub,(bad)
there are many causes.
1: OS corrupted, XP loves to do that
2: XP and vista are now dead, so the driver updates are dead.
2b: that means you must load all the old software by hand.
3: step 2 in the users guide tell you insert CD and install the software. do that, ? re-install all that?
i went to epson.com
my guess is they do NOT support legacy products they sold
at all. not even for XP.
print Q (queue)
what error,? only this matters now and printer status lamps.
does the self test pages work?
does the printer status leds show errors, if yes printer its self is bad.
ink problems, etc. jams,
yes xp has bugs in the queue manager, (tricky to fix, can do)
$20 is cheap good rate for help... such a deal !
If more complex it will cost more.
if the queue is jammed, only (no errors there)
then disconnect the printer. usb cable
then click the queue manager and clear the queue out.
then start fresh.
do a simple short text file first. to see it it works.
notepad, edit, hello printer " file , print.
the service manual is here free to read.
https://www.manualslib.com/products/Epson-Stylus-Tx125-4060230.html
Sep 01, 2017 | Compaq Presario CQ60-212US Notebook
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Epson Printer CX4800
cx4800 error light and on light keep blinking
May 12, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Have changed inks which were low and now have left and centre red lights flashing and printer will not operate.
Check for epson status monitor : General error or reach end life service ? Flashing alternately mean printer need to reset waste ink counter.
Mar 15, 2010 | Epson Stylus photo C87 InkJet Printer
Epson Stylus SX100 General Error
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you.
Sep 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson pituremate
Mar 24, 2006 | Epson PictureMate InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
140 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
