Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer gets stuck on c05 in diagnostic mode
watugot
  • 290 Answers
SOURCE: My washer is stuck in the pause mode
This sounds like a broken door switch. Open the door and look on the right side of the cabinet where the door latch goes in. About 4-5 inches above that there should be a small actuator that sticks out about a quarter inch. You should be able to press it in and out easily. If you only have a hole with nothing sticking out, the actuator is broken. You can break off a round toothpick and insert it in the hole, leaving about a quarter inch sticking out and gently close the door and see if the machine starts up.
Post back and let me know what you find.
Thanks/Mike
Posted on Oct 31, 2007
SOURCE: whirlpool duet how to enter diagnostics
look for tech sheet. this will tell you how to enter machine into service mode. Its located either behind bottom kick panel. or under top panel.
Posted on Feb 19, 2009
jsrock516
  • 5911 Answers
SOURCE: duet washer has f6 diagnostic code
The following link explains how to troubleshoot the "F06" error code:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The first step in toubleshooting this problem is to check all the connector plugs between the Drive Motor, MCU and CCU. Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
If the tachometer is determined to be the cause of the problem, it is part of the MCU. The MCU is not serviceable and will require replacement. Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. For more in depth troubleshooting tips refer to your technical data sheet that came with the washer. It is located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, dianostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
If you have questions, or require additional assistance, please let me know.
NOTE: For better access to the toe panel screws, you can prop the two front feet of the washer up. (A 2x4 works real well for this).
Posted on Dec 07, 2009
jsrock516
  • 5911 Answers
SOURCE: washer is stuck in
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. .
Posted on Jul 24, 2010
richroth
  • 9472 Answers
SOURCE: Whirlpool Duet GHW9100LQ F02 Code after C6 diagnostic
Yes, the drain pump is faulty and needs to be replaced. Here is the part to order. If you would like the service manual for that unit, post back to me and I will send you a link to it.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
Posted on Nov 22, 2012
Kenmore Elite HE4T washing machine diagnostic test not completing - getting stuck on C05
http://www.managemylife.com/images/6975/original/346.jpg?1303498921
According to this it could be either the Computer (don't think so but don't rule it out just yet.), the fill valve, or the heater. Appliance Repair Forums
This link will help you test the fill valves.
This will link you to a service manual for the HE3T washer which is very similar to yours and the diagnostics and tests will be the same. https://www.ifixit.com/Document/1074/.pdf
Jan 20, 2017 | Kenmore Washing Machines
Washer stuck in pause mode
Check the door switch. I think you have posted twice.
Thanks/Mike
Oct 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer wfw94hexw2 lites up but wont run
sometimes on the duet models I have worked on with similar pattern. the thermal shut off fuse is out and the only thing you will get is blinking but could also be a bad motor control board? u should try and run a diagnostic and it will give the some error readings to let u know what is wrong, if u put ur model number in a youtube seach u may be able to find out how to put ur washer into diagnostic mode
Jul 26, 2014 | Whirlpool Washing Machines
My dryer is stuck on "Control Lock"
See if you can get into the diagnostic mode. If not, you will need to replace the "user interface" on the machine. Here is a link to the part if you should need it.
ACTIVATING THE DIAGNOSTIC TEST MODE 1. Make sure that the dryer is in the "Standby" mode (plugged in and all of the indicators are off). 2. Press the following control panel keypad sequence all within 5 seconds: More Time-Less Time-More Time- Less Time. 3. All indicators on the console should now be illuminated with "88" showing in the "Estimated Time Remaining" display, if this test mode has been entered successfully.
Dec 26, 2010 | Whirlpool Duet Front Loading Dryer Rack...
How do I get the door unlocked on my duet washer
Remove your service panel and get the tech sheet out. Use the tech sheet for diagnostics it might save you some coin.
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get our whirlpool duet washer control lock light off ?
Hold the end of signal volume button down for 3 seconds to turn the control lock on and off.
If that does not work then: a) unplug the washer or b) put the washer into diagnostic mode using the instructions from this thread http://applianceguru.com/forum2/1540.html.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9600T Washer - How do I run diagnostic mode?
Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet how to enter diagnostics
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a whirlpool duet front load washer (GHW9100lW1) and the status is stuck on CONTROL LOCKED and i can't change it and the machine is no longer working.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Dec 17, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
237 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
