Question about Freezers
Kenmore freezer drawer frozen shut
My kenmore freezer drawer is frozen shut. This is due to a faulty ice maker that caused it to overflow and freeze the glide rails. I know because it happened before. I was able to get the door open that time by force and thawed the freezer. This time it is not budging. I've directed a space heater for 12 hours at the outside wall on the side of the ice maker. No go. I've unplugged it and let it sit for 8 hours. Still won't move. Now I've kept it unplugged and added the space heater again. Still frozen. All the posted on line help explains what to do after it's opened. But I just need advice on how to get it open. Tools, methods, anything. It's a Kenmore bottom freezer.
  • 1,869 Answers
Use your wife's electric handheld hair dryer as close to the rails as you can once slightly open you can use table salt/ice melt to free the drawer or; turn up your house thermostat to about 80 degrees for the day while you are at work; the drawer should be free by the time you get home.
Posted on Nov 18, 2013
  • wendy_w_star Nov 18, 2013
    Thx, are these two possible actions best done while the refrigerator is unplugged?
5 Suggested Answers
  • 27 Answers
SOURCE: Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Posted on Jul 26, 2009
  • 415 Answers
SOURCE: Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Posted on Aug 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Posted on Feb 05, 2010
BIKER T
  • 909 Answers
SOURCE: The bottom drawer on my Kenmore 4.8 chest freezer
normally it is an ice build up on the inside. Suggest overnight defrost to sort this problem out.
Posted on May 28, 2010
Freezer will not shut off some things frozen, bread and ice cream soft
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Kenmore Coldspot side by side ice maker not working, red lite bliking
Often I find your ice maker on the Kenmore side by side thefill tube frozen. The fill tube is ablack rubber hose located above and to the right of your ice maker. Simplypinch the tube to see if it frozen solid. If it is, use a hair dryer set onmedium to defrost the fill line. http://www.on-timeappliance.com/kenmorerefrigeratorrepairdallastx.html
Mar 24, 2012 | Kenmore Freezers
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Mar 07, 2012 | Siemens Freezers
Ice maker tray over flows and clumps ice, water freezes in drain at bottom and water will come out of the front of freezer door. this does not occur all the time just when it gets a hankerin too. could it...
Good day,
The normal operation is for the ice maker to harvest a batch of cubes, and then just before competing it's cycle, to open the valve to add more water for 7 seconds then shut off smartly.
At least 50% of water valve problems cause an overfill problem, because of internal wear etc. that does not let the valve close on time. This causes an overflow problem to the ice maker, and all the problems you described.
It should be corrected as soon as possible, since they have been known to throttle open and never close. Should it be overnight or while away, the damage can become quite serious.
Feb 12, 2010 | Maytag Freezers
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
128 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
