Question about Russell Hobbs Kitchen Appliances - Others
Russell hobbs toaster 13899 bread carriage lever won't lock
The operating lever for the right hand pair of toasting slots does not lock when depressed. The heating element works if the lever is manually held down. The left hand lever is fine
4 Suggested Answers
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
SOURCE: russell hobbs toaster 9379 bread carriage handles
bought a new toaster I would like any account you have created for me to be deleted. thank you
Posted on Dec 23, 2009
SOURCE: My toaster doesn't stay in the down (toast) position unless I hold it down
I solved this problem on my Cuisinart CPT-90 Classic Style Toaster twice for two different problems. Of course: make sure it's UNPLUGGED while working on it and WATCH IT several times when testing so you can unplug it first and then extinguish it if it catches on fire.
1st time: There is a small solenoid mounted in the center of the circuit board. When the pop up mechanism is pressed down the circuit energizes and the the solenoid magnetically locks a plastic clip that holds the spring loaded pop up mechanism down until it's done toasting. The plastic mounts for the circuit board broke or weakened until the whole circuit board would tilt up and the solenoid clip would slip under the spring tension. I used a plastic tie-wrap to hold the circuit board firmly in place and that worked to this day.
2nd time : The four copper reed tabs can be miss aligned. If they
do not make contact, the circuit will not energize the solenoid.
The reason they warped was that, over time, the contacts build up carbon and have more resistance. Resistance equals heat. The
plastic base of the copper reed switch melted and misaligned the reeds. The second time I cleaned the reeds and bent them back into position, The third time the the plastic was to badly burned to be reliable. If I had cleaned the contacts once a year, it probably would still work now. I haven't found a place to buy a replacement reed switch so my toaster is toast. If anyone knows where to order them, I'd like to know. If the white plastic base of the reed switch is not melted, then they can be cleaned and aligned.
Note: When aligning the copper contacts, don't just hold down the pop up mechanism. The pop up mechanism will push lower than the position for toasting. Push it down and then hold the solenoid clip instead. Then the two center reeds will be at the correct spread.
Posted on Jun 26, 2010
This is a double toaster.Model number 18140. Right hand side of product fails to stop/lock down (its electrically operated)
You need to open it up. These toasters have small mechanical locking devices under the cover. you need to see what isn't working.
Mar 17, 2016 | Russell Hobbs Kitchen Appliances - Others
Russell hobbs problems
It sounds like the heating coil is not getting power on the side that is not toasting. Return the unit to the retailer that you purchased it from and get a different model or a refund.
May 03, 2014 | Kitchen Appliances - Others
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
Aug 04, 2009 | Kitchen Appliances - Others
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Plastic knob broken on Toaster
Have you tried gorilla glue?  It is very solid but messy stuff.  be careful with it and try to clamp it some how.
Nov 16, 2008 | Russell Hobbs Kitchen Appliances - Others
Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Aug 25, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
Russell Hobbs Toaster Model # RH4T9379
It would be NICE if you didn't abort the chat session when I was tyring to help you. Geez!!
Dec 03, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
62 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
