Question about Kohler Plumbing
Kohler push pull kohler bathtub faucet will not turn off completely
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
The Drain handle can be adjusted under the sink, you can remove the retainer and adjust the lever.
Posted on Dec 29, 2013
4 Suggested Answers
  • 68 Answers
SOURCE: Cannot pull out spout to replace o'ring of Kohler Faucet 10416
the pic u have up doesnt show it being a pull out u trying to fix airater?
Posted on Feb 07, 2009
  • 23 Answers
SOURCE: bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Posted on May 12, 2009
  • 25 Answers
SOURCE: My Kohler bathtub hot water faucet 77809-AA needs
My husband is a plumber. He says u need to pull it off with pliers. U need to just pull it off. It may take a couple tries, but it should come out.
Posted on Jan 04, 2010
The water runs when I turn the main shutoff back on even though the faucet is off
A grommet seal has disolved. You need to turn off the water main and replace or rebuild the affected shut-off valve or faucet. Use a Monkey wrench. .
May 29, 2015 | Kohler Home
Brand new kohler cruette. attached cold and hot water fine. when snapping in the pull out faucet hose it sprays all over under the sink
Hi rysenga, the problem is an omission of directions. The section 9 directions are the worst offender and left me never again to purchase a Kohler product. First, this connection for the pull out hose to the outlet fitting should have been a screw on connection. Should have been. Ok it was not, I'll get over it. But the directions never mention having to install the white plastic bushing. Not at all. Nor does it mention that the bushing should be put on the outlet first and then push the hose connection in. This omission is a huge one, but should help anyone else reading this complete the install. Find the oval lip white bushing and install this first on the body, and then just push the connector in. Done.
Sep 02, 2012 | Kohler Plumbing
Bathtub faucet won't turn off
You need to shut off water to bathtub take cartridge out(be sure to note or mark position cartridge came out so it goes back same way)replace springs and washers.Pop out old springs and washers with small screwdriver or pick tool.
Jun 03, 2011 | Kohler Plumbing
My kohler faucet is leaking. I know how to fix it but the casing is secured to the marble sink. Do I need to remove the cartridge from underneath?
you generally can work on the faucet from up above. turn the valves off underneath in the cabinet area and remove the knobs or handle . From that point everything should be visible that you need to do.
Apr 09, 2011 | Kohler Home
Hot water faucet on an older kohler two handle bathtub faucet only goes on slightly. Will not completely go on and can't force it any farther.
Turn off the water supply to the sink. Now remove the handle on the hot. next remove the seat. When you remove that, you should have a rubber gasket on the bottom. You can take that to any home improvement store. Your seat has gone bad. They make kits for it.
Dec 18, 2010 | Home
My Kohler bathtub hot water faucet 77809-AA needs to be repaired and I can't get it off. I took the cap off and took the screw out, but it won't budge from there
Dec 22, 2009 | Kohler Plumbing
Plumbing Logo
73 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
