Question about Gateway MD2614u Notebook
Gateway md2614 shuts down
One more question if i clean that heatsync with alcohol on the cpu area and that doesn't resolve any suggestion for any software to dignostic on the laptop to see whats going on thank you
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Shutdown issues can occur for different reasons besides overheating. If it IS heat, then it could be that your vents are clogged with dust. Used compressed air and blow into the areas on the bottom and the sides that look like grills for air flow. I'd try this first.
Another reason for shutdowns could be a bad connecting AC cord alongside a failing battery. If you laptop is always plugged in, then the battery can lose its ability to hold a charge. If you're AC tip wiggles too much when plugged in, it could be a broken DC-in jack which may not be worth the repair as they are usually soldered to the motherboard.
Easiest way to see if the AC is the issue is to remove the battery and gently wiggle the cord to see if it powers off from the movement.
Also if the AC cord is twisted up too much it can cause a break in the cable. Examine the cord length and see if you have any bulges, or even cat or dog bites.
Posted on Nov 18, 2013
4 Suggested Answers
anjana03
  • 361 Answers
SOURCE: My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Posted on Jun 12, 2009
  • 3 Answers
SOURCE: where do i insert a memory card into a gateway
It depends what type of memory card you are referring to.
USB memory will plug into the USB ports on the left side of the laptop.
If you are using a Memory Sick, Memory Stick Pro, Mini Secure Digital, MultiMediaCard, RS_MultiMediaCard, Secure Digital (SD), or xD-Picture card they will go into the memory card reader on the left side of the laptop about 2 inches from the front of the machine. ** NOTE: this is the bottom slot.
If you are using a Type 54 ExpressCard it will also go in on the lfetside but this slot will be above the Memory card reader slot mentioned above.
Good Luck! :-)
Posted on Dec 20, 2009
  • 309 Answers
SOURCE: Cooler Problem ?
There are devices you can purchase which aids in pulling more air through the system and keeping it cooler. One which I purchased and am quite pleased with is by Antec. It is a dual fan unit that is powered by one of your USB ports. You place your laptop on top of the unit, power it on, and it works wonders at keeping your system free from damaging heat buildup and those annoying shutdowns!
There are other units made by other manufacturers available as well. Some more expensive, some less. I have always had good luck with products from Antec and their price was reasonable as well.
Posted on Jan 24, 2010
Gateway intermittent shutdown
I installed a new alternater th battery is new
Dec 27, 2013 | Gateway MD2614u Notebook
I 'm looking for any tips you may have with regard to replacing the Acer Aspire LS-6902P Series Power Board w/ Cable
completely remove all screws and dissassemble laptop (youtube will describe how).
Clean laptop completely and inspect for water damage spills clean with tootbrush gently be careful if corroded not to remove components with your cleaning.
i use an alcohol 99% after a water dish-soap solution on toothbrush but is like digging up dinosaurs one must be gentle and slow.
watch the fumes on alcohol are explosive with a spark.
I would clean the fan area and cooling fin area at same...
and put new heat-sink on CPU and GPU.
take pics of )and put screws in multi containers to keep track of them.
be gentle on mother board and screen.
;0
Oct 25, 2013 | Acer Aspire 5750-6589 Gateway Nv57h Cpu...
Play station 3 keeps knocking off every 10 seconds
Depending on how it is shutting off and if there is an error message given or not, it sounds like an issue with the heatsync on either the CPU or GPU which can be fixed (if you know how to take apart a PS3) By reapplying the thermal paste onto the heatsync and overtightening the screws holding them on.
Sep 12, 2011 | Computers & Internet
CPU shuts down after a few seconds. The CPU heatsync fan shuts down as well.
i think u need fomate ur pc
bcoz some times come like this problem
due to os corrupt.......
Feb 02, 2010 | Computers & Internet
Shut down after 5 - 10 min.
the most likely case is CPU-OVERHEAT EMERGENCY POWEROFF command executed by motherboard in this case apply new thermoaste on cpu, and clean fan/replace on bigger if doesn't help/cpu is overclocked
Sep 22, 2009 | VIA ASRock K7VM3 Socket A/...
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
No signal then orange light on my Gateway FPD1975W 19Inch Monitor
If you have a add on display/graphic card in your CPU then shutdown the system, open the case and try to press the display card gently. Sometimes if the card get loose the display will not come.
If you don't have add on display then try to press the Memory gently after shutting down the PC and try the signal again.
If not resolve let me know whether any beep/sound is coming out of your CPU box?
Rate my answer please.
Thanks.
Jan 04, 2009 | Gateway FPD1975W 19" LCD Monitor
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
PC gets shut down
this means that it is overheating. you can do many things here. 1. take off the CPU cooler, and reapply some heatsync and see if that fixes the problem. 2. buy a larger, or more efficient CPU cooler, newegg.com is a great place to find good parts that are cheap and come with customer reviews already. 3. change the settings in your bios to allow the CPU to become warmer (do not go above 75 degrees) without shutdown or alarm.
Jan 06, 2008 | Audio Players & Recorders
CPU Fan.
Make Sure your thermal compound is properly placed, check the temp of your CPU. CPU might be overheating due to destroyed layer of compound and therefore Fans run faster...
Sep 27, 2006 | Gateway 500GR PC Desktop
Gateway MD2614u Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
