Question about Zanussi FLE1416W Front Load Washer
Zanussi zwg 5125 start/pause button flashing - Zanussi FLE1416W Front Load Washer
SOURCE: Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Posted on Jul 30, 2007
  • 1294 Answers
SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
SOURCE: Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Posted on Jul 11, 2008
SOURCE: hi my zanussi zwf1432s stopped halfway through
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Posted on May 05, 2010
tunde007
  • 2382 Answers
SOURCE: i have a zanussi 1200 6kg washing machine.
Hi, the flashing red light is an indication that you have a problem with your machine not spinning and draining.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Nov 20, 2010
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
User manual for zanussi washing machine ZWG 7160 P
how do i replace washing machine drain hose on zanussi zwg 7160p
Jan 16, 2012 | Zanussi Washing Machines
ZANUSSI FLE1015W,THE problem i have is that once i turn on the machine and press fabric button the program lights come on and the start/pause button light flashes i press the start/pause button a sound is...
Have you selected a program?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Zanussi FLE1416W Front Load Washer
Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
Feb 15, 2009 | Zanussi TC7114W Electric Dryer
Zanussi washer
Press "end of cycle" button to clear.........................
Jan 04, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FLE 1015W
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FLE1416W Front Load Washer Logo
101 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
