Question about Philips Magnavox 42MF521D/37 Television
Cannot get att remote s10-s3 to control tv
I have tried all codes
2 Suggested Answers
gopakumarg43
  • 75581 Answers
SOURCE: codes for Magnavox TV wlDVD to work with ATT U-verse remote
Four digit universal remote codes for Magnavox TV are:
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Setup Proceedings.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Posted on Jul 06, 2012
How do i find a code for my tcl tv for a s10-s3 remote
The code will be in the remote control, if it is compatible.
Nov 19, 2017 | Televison & Video
I need the programming code to my ATT, S10-S4 remote to control my HCT TV, Model HPP-42HCB.
The codes are stored in the remote. If you are unable to control your HCT TV, you may have to substitute a programmable remote to find an appropriate code.
Jun 20, 2015 | Televison & Video
Att uverse remote control code
You have this backwards. What you are seeking is the ATT remote code for your Panasonic projector. The codes are generated by the remote
Jun 25, 2013 | Panasonic Office Equipment & Supplies
Previously Requested but no solution: I cannot reprogram the remote for this TV so that I can connect to AT&T Uverse Satellite. I do not have a mdoel number for the TV remote that came with the...
Hello, Mr. Ross.
I'll be more than happy to assist you with this and all of your other Uverse concerns.
First please write these codes down, these are the TV codes for your Mitsubishi TV,
0093, 0150, 0178, 0019 (we are going to do trial and error for these codes till we hit the correct one for your TV.)
Please turn the TV on and point your ATT remote control.
Okay, using your ATT remote control, please press and hold the TV button together with the "OK" button.
All four modes should flash twice indicating that we are programming your remote control.
Now, enter the 4 digit code and the selected mode (in our case it is the TV) should give a long flash.
Then press OK.
Try to turn your TV off and check if it would respond
If not, please redo the steps but this time use the other codes I provided earlier.
If these codes wont work we will do the automatic code finder if you are using the "black" AT&T Uverse remote control.
Using your ATT remote control, please press and hold the TV button together with the "OK" button.
Then press the "scan/ff" button repeatedly with atleast 1 second interval till it turns your TV off.
Press OK then try to turn your TV on again.
Whenever your remote won't respond, try pressing either the AT&T button on top of the remote before any other buttons or the TV button beside the ATT button.
Aug 10, 2011 | Mitsubishi Televison & Video
I have a at&t uverse remote and am trying to program it to my emerson tv,but i dont have the codes
Go to their website to find out a download copy of the codes if not just buy a new one.
Jun 29, 2010 | Televison & Video
How do i find the code numbers to program my att uverse remote control
*To Manually program the AT&T universal remote control to your
TV here are the steps
Factory Reset the AT&T Remote Control:
* Press the ATT button and the OK button at the same time for 2-3 sec. release them at the same time. The ATT button will blink twice then enter the code 922. The ATT button will blink Thrice. IF not repeat the step
* Press the ATT button then check all the function of the remote (Volume, Channel, Menu, Guide)
Note: you will see that the max volume is 25. Dont worry its the volume of the receiver
To Program Your TV:
* Press the TV button and the OK button at the same time for 2-3 sec. release them at the same time. The TV button will blink twice then enter the code. Click Here to see the manucafturers list of codes. After Entering the code TV button will blink thrice. IF not repeat the step
Note: After you program the tv make sure to press the ATT button. then now check all the function of the remote. Follow the instruction and it will work. If you press the power button the TV and ATT Recievier will turn on and off at the same time
Thanks for using Fixya.
May 30, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Need att remote control mfg. no. for magnavox tv
i do not think it would work with your tv. there has been problems when tech installed uverse on dozens of tv. you can try to purchase an universal remote and see if that works. it is just like a jvc vcr/dvd player/recorder which will not work with any tv but jvc. you can also call att tech to help
Mar 05, 2010 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Philips Magnavox 42MF521D/37 Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
