Question about Black & Decker BL5900 ProBlend Work Top Blender
Spare parts? Hello there.... I need to buy a replacement plastic ring for the base. It was screwed on too tight once, and is now cracked. Where can I buy a new ring? thank you very much!
  • Anonymous Feb 03, 2008
    I have the same problem
  • Anonymous Apr 14, 2008
    same problem... live in Africa, so no spares... but superglue has held it together, in spite of being broken in two different places.  Worth a try.
Http://estore.fox-international.com/
Posted on Jan 20, 2008
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
You can order this part Black and Decker Blender Base Collar Ring BL5000-11
I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
May 26, 2009 | Black & Decker BL1900R Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Leaking blender
It could be the gasket, could definitely be that crack in the collar, and even possibly the blade assembly - here is the official website to get all of those parts:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4154&linkon=subsection&linkid=112&secid=53
-Tha Mp3 Doctor
Mar 31, 2009 | Back to Basics 600 Smoothie Elite Work Top...
Maximatic EBL-1000 Elite Cuisine 10... Problem:
Brandy,
-the gasket is a flat rubber ring
-it is used to seal the space between the glass carafe and the plastic carafe base that fits into the base unit
-so the order is glass carafe, chopper blade, gasket, plastic ring...turn this on tightly
-place the whole carafe unit onto the base unit
NOTE: it does not fit firmly...suggest that you hold it firmly before you turn the unit on
so I hope that `fix-ya` works....if not...then ask.
...as any rating than this actually lowers my rank...just the way fix-ya works
bearb
Nov 10, 2008 | Maximatic EBL-1000 Elite Cuisine 10 Speed...
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Black & Decker BL5900 ProBlend Work Top Blender Logo
195 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
