Question about Dryers
Bosch classixx 7 vent hose light flashes every 10 min
  • 228 Answers
SOURCE: key symbol flashing on a Bosch Classixx 1400
child lock is active usually pressing start button for 5 secs or more cancels it
Posted on Dec 15, 2009
  • 414 Answers
SOURCE: manual for WTE84105GB
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Posted on Jul 08, 2010
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
  • 39 Answers
SOURCE: Bosch vision 300 gas dryer shows error E12 evry
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Posted on Jan 19, 2011
  • 196 Answers
SOURCE: bosch classixx 1200 express spin light
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Posted on Feb 28, 2011
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx tumble dryer 7
You think the vent is clear but it isn't. The inside could be full of lint in the tube through the machine or the air travel through it is impaired somehow. The thermal indicator may have some lint on it also. Get one of those - As seen on TV- long lint snakes and use it to clean the whole visible area below your pull out screen. Especially the thermostat you can see there. If you have access to a compressor and air hose --- blow out the lint in the tube with high volume of air. Then turn on your machine and listen for the lint traveling through the vent exhaust. The thermostat may have a glaze on it that impairs the reading. Clean it off if you can.
Jan 06, 2014 | Dryers
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Flashing container light. what is this? Dryer
Try taking out the lint screen and scrubbing it well in the sink with hot water and a brush. If you havent cleaned out below the lint screen, get a vacuum and a crevice tool and remove any standing lint as well as cleaning the vent. Bosch lint screens clog easily especially if you are a big fabric softener user.
Nov 20, 2010 | Bosch Classixx WVF 2402 Front Load...
Keep getting error f17 on my bosch classixx 6 washing machine
My old Bosch only had a filter in the machine (where the hose attaches. My Exxcel has a filter IN THE HOSE at the tap end too. I removed that one and it made a big difference !
Dec 17, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Mar 06, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Dryers Logo
15 people viewed this question
Top Dryers Experts
