Question about Toshiba SD-V392 DVD Player/VCR
Dvd player Door will not open manually or with remote.
  • 6 more comments
  • Anonymous Nov 05, 2007
    I have had the same problem off and on. When powered on it gets stuck to "hello" and would not open. When it did open it worked quite well. However, currently it won't open at all. It is a known problem listed in the users' manual where it states to turn the power off and back on. I tried that many times lately but it won't open.
  • Dave5card Nov 05, 2007
    The dvd player makes a buzzing type sound when plugged in and none of the functions work. There's a dvd in the dvd player that is a rental.....it's return is slightly late.....tried the take plug out put it back in but no luck....originally this happened the odd time but then it would go back working as normal.
  • rav4ravi Nov 15, 2007
    My T600D has the same problem (door won't open, but functions well!). I had to open the player box to get my disc out. Now I want to contact techSupport or return the item since it is only 5 months old.
    Any other ideas/suggestions/hints?
  • Anonymous Nov 20, 2007
    dvd door not opening
  • Anonymous Dec 05, 2007
    Door will not open - it displays 'open', 'close', 'no disk', so it seems to think it is working okay. Have tried powering off. I normally switch off at mains overnight - could this be the cause (doubtful I know).
  • Jim88 Dec 24, 2007
    DVD door will not open.
  • Anonymous Dec 29, 2007
    how can I open the dvd door
  • Anonymous Jan 04, 2008
    Door on VCR recorder would not open to eject tape on my Philips DVP3340V.
    The cause was that a finger on the end of a lever that actuates the door had slipped out of the right end of the door. The solution was to remove the cover on the unit, and manually reinsert the finger into the door. The plastic is flexible enough so that you can do this without unscrewing anything. Now the
    unit works fine.
    Please note that this is a mechanical problem affecting the VCR door, and not the problem described at the head of this thread.
The drive belt is most likely broken inside.The motor runs but doesn't open. This requires a new belt. Unfortunately I have trouble finding a new belt and if you open it you void any warranty still in force. So unless you find a belt, or a repair man, you will most likely need a new unit.
Posted on Jun 30, 2008
  • Anonymous Jun 30, 2008
    http://www.electronix.com/catalog/advanc...
    Here is where to get the belts if you need them. Just got it from someone else on this thread.
Symptom : my dvd811 door would not open, but displayed 'open', 'close', 'no disk' as if it thought it was working.
After keeping 'open' button depressed on set and remote, and switching off and on, and waiting, with no success - read suggestions here, disconnected it from everything, took it out, re-connected to power, switched on and it worked first time. DVD players work in mysterious ways.
Posted on Dec 05, 2007
Do replace the loading belt in the loader unit ,the belt is serrated (full of cracks) and is very dry .The belt slips when pulling .
Posted on Nov 20, 2007
SOURCE:
How to open the DVD Player compartment door if the remote does not work?
There a button on the right side of the disc tray said open/close press this button ur disc tray will open manually.Press it again it will close.
Apr 27, 2010 | Televison & Video
Can't get the door open to put in a DVD. Player says no disc but the door won't open with remote or manually.
If you look at the front panel of your CD player you will notice a very small hole. Using a VERY straight Paper Clip push in about 1/2 inch in this hole then pull the drawer out.
Mar 07, 2010 | Cyberhome DVD Recorder - DVR1600
Power is on door tray will not open with manual or
the possible problem of it is a defective mpeg board or the belt in tray to make it open if the motor have a supply to turn the motor the problem is the belt but if it has no supply from the mpeg to the motor the defect is on the mpeg board
Nov 18, 2009 | Denon DVD-2910 DVD Player
Door won't open on dvd or video player
It is possible that there is a piece of something that is stuck between the door and the disk drive.If it is you could try GENTLY manually opening the drive and taking out the piece of whatever with a toothpick or tweezers.Your remote also might need batteries or your DVD player might just be sunk.Hope it helped
Oct 15, 2009 | Televison & Video
My remote for MWD2205 dvd/vcr player won't do anything except open and close dvd door. I bought it used and it didn't come with instructions.
Hi dear,
Please use the remote very close to the dvd so that the dvd player can receive the signal properly. This can happen with low quality dvd players. If the problem persists, then consult to a dvd player mechanics to replace your remote.
Thanks.
Jun 08, 2009 | Philips MWD2205 DVD Player/VCR
The disk door couldnot open
On the front of most DVD players there is a button with EJECT printed under it.
The same button is normally on remotes.
Try pressing this button.
May 04, 2009 | Televison & Video
Cannot open the dvd door on the ch-dvd300 it is turned on but cannot open. the remote battery is not working for the dvd.
Remove the cover, remove the disc if one is present, manually push the door open if there was a disc in there or not. Place cover back on, let me know if that doesn't work.
Oh, please rate this solution.
Thanks,
Worldvet
Jun 20, 2008 | Cyberhome Televison & Video
Disc removal/ CH-DVD 300
On the bottom of the DVD player, there is an "emergency slot." I used a knife to push the botton over which manually opens the door to get your DVD out. However, I can't turn my DVD player on either. And can't figure out what the heck to do??!?!?!?!
Dec 23, 2007 | Cyberhome CH-DVD 300 DVD Player
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba SD-V392 DVD Player/VCR Logo
279 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
