Question about Electrical Supplies
Exhaust temperature sensors location on kohler 5e
Generator shuts down after minutes or hours of operation
SOURCE: generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Posted on Sep 21, 2008
CarlGehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
  • 208 Answers
SOURCE: 4000 watt onana generator. Shuts down after a
contact the manufacturer for detailed descriptions of the code and go frome there
Posted on Jun 22, 2009
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
  • 142 Answers
SOURCE: onan generator dies after 2-3 hours of running ,
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Posted on Jul 10, 2010
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
5e generator shunting down after 6min
Check oil pressure switch, and oil level and type
Jul 23, 2012 | Kohler Electrical Supplies
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
mike
Sep 24, 2009 | Kohler Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
