Question about Garden
Troybilt blower w/walbro WT682. Starts & idles fine, stumbles on high speed setting, never reaching high speed. It keeps running but only a little faster than at idle. No backfire.
Cleaned and rebuilt carb
slohry
  • 87 Answers
SOURCE: Echo PB 2100 Leaf Blower will not speed up
Remove the muffler and clean the exhaust port, spark arrestor screen and muffler intake.
Posted on Apr 09, 2009
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
carputers
  • 255 Answers
SOURCE: 1 Solution for
that adjustment is a cap the real screw is under that cap/1/4 turn thing.
u need to pop it off or drill it out to get to the real screw. its a safety thing so as not to run it to lean and burn up the motor. lean it out a little at a time, i mean a little like 1/16 of a turn, test and adjust again if needed.
Posted on Oct 21, 2009
SOURCE: Engine will not reach full operating speed, needs
Need to replace exhaust? Are you for real? Guru of what? Asinine answers?
Posted on Nov 23, 2009
SOURCE: The engine on my Red Max EB7000 backpack leaf stalls or smothers.
The most common air leak problem on redmax or any 2 cycle engine will be found between the gasket between the cylinder and crank case. One person mentioned the blower runs fine for 15 minutes or so, then bogs down. Here is what is happening: the air leak from the cylinder gasket is causing a leaner gas to air mixture, thus causing the motor to run hotter. As the engine overheats, the aluminum piston expands against the chrome plated walls of the cylinder, causing the piston rings to get tight. Thus, more friction, in turn, causes the piston to not move as freely up and down in the chamber. If you keep running it like this you will damage the cylinder walls, the piston and the bearings. Remedy: The best thing to do at first sign of this problem is to purchase the cylinder gasket, the oil seals on the crank side and the fly wheel side, and the gasket kit that comes with the intake, muffler, and insulator gaskets. Replacing all of these gaskets at the first sign of bogging down after the motor heats up will extend the life of your blower. We have 18 of these blowers, and in every case where the crew leaders were complaining of the blower working fine for the first 15 minutes between job sites, this was the problem and the remedy.
Posted on Dec 11, 2009
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
Feb 09, 2017 | Ryobi Garden
I have a new Ryobi RY08420 new out of the box. It starts fine and seems to idle fine. When I go full power, it is almost like the choke lever vibrates further back and causes it to bog down. If I adju
Running too lean at full throttle. Yes you need enrich the high speed mixture a little but make sure the blower has warmed up first that if the carburetor is adjustable.
Nov 21, 2014 | Ryobi Garden
I have a echo pb251 gas blower,stop running,has spark,rebuildt carb.fuel filter,after no start,plug is wet & sparks but wont hit/start
screw air mix screws in the out like a half turn each, one controls the high end speed and one controls the idle, do idle first and adjust just a little rich then do high speed screw.
Nov 03, 2014 | Echo Garden
Idle adjustment
I do not think this will cause any damage. If it starts and runs fine I think you did a good thing.
Nov 06, 2013 | Toro Lawn Mower With Toro Power Tools
How do I adjust the carburator on my Stihl BG55 leaf blower
You can adjust the carb by turning the screws counterclockwise, the H high speed screw is the one closest to the Air Filter and the low L is closest to cylinder (Motor) Change your spark plug first, then run it at wide open throttle and slowly turn the "H" screw counterclockwise a little at a time if it blubbers then it is too far out (rich) so take it the other way till you reach peak R.P.M. s -then back it out opposite way till the sound of the R.P.M's just starts to drop and High speed is set. the low speed is adjusted at idle to where there is no hesitation when you pull throttle open, keep trying till you get a good acceleration with out hesitation, and you are good to go!
Nov 12, 2011 | Garden
Two stroke weedeater starts,idles, but boggs down when gas is applied. it won't reach top end speed.
have a look on side of carby should see 3 small screws a high and a low idle screw , when running unsrew the high idle srew slightly and it should fix
Sep 18, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Engine starts fine but lacks power until it warms up for 2 to 5 minutes. Carb is ok, replaced head gasket. Just started doing this
If it starts at completely cold to fine tune the high jet adjustment.first off the high speed jet should be initially set at 1 1/2 turns out from lightly bottomed all the way in. next when you do your prestart routine,choke all the way on,primer pumped two times,throttle set at the high speed position,ignition key on,fuel line turned on.(this is my prestartup for my 8hp tecumseh)yours may be slightly different.use whatever starts your machine the easiest! once my machine starts up i can almost immediately turn the choke completely off. i can do that because the high speed jet is opened enough or rich enough for the engine to run.if you adjust the high speed in it will lean the motor out(you found that to be true!) to where it will miss and backfire and eventually quit. start at 1 1/2 turns out and start the engine,once the engine starts if you take the choke off right away use what it does as a guide to high speed adjustment. if the engine quits turn the screw out 1/4 turn and so on.use the very first cold startup as the test for high speed mixture adjustment. at completely cold startup you have the jet adjusted correctly when the engine will sustain itself when you completely take the choke off very shortly after startup. let the amount of choke you need at cold start to keep the engine running be your guide.too lean and the engine will not stay running without the choke at all,too rich and the engine will not pull under extreme loads and will show signs of black soot out the exhaust. you want the jet adjusted so within 5 seconds of cold start the engine will stay running with no choke at all. find that needle setting ( don't ad any more!! ) and you'll be good to go.keep in mind the above is not optimum and is a little rich but you will like the way it starts,stays running,and overall performs as adjusted above.
Oct 03, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
May 19, 2010 | Craftsman Blower Attachment
How to adjust the low and high settings on the carb
With all the new EPA guidlines on emissions there are many new type of carbs.The older type was easy, If its a walbro or zama brand and it has 2 adjustment screws as well as an Idle speed, preset the low and high at 1.25 turns out from set, start the saw, run it to full throttle,adjust the high speed needle counter clockwise untill you hear the engine start to flutter. You want to year the flutter about once every 4 seconds.then let it idle,adjust the low speen till it runs smooth then make it 1/8 turn richer. Many of the new carbs require special tools to adjust, not brain surgery, just to keep the air cleaner..
Oct 27, 2009 | Poulan Garden
Craftsman mini tiller starts good but will not idle nor run fast
i'm having the same problem. cleaned carb but didn't help. I found that if I spray starting fluid on the gasket between the carb and the motor it speeds up. I'm going to try to find a new gasket, I can't tighten it anymore.
Good luck
Jun 30, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
