Question about Water Heaters
Intertherm 54 gal hotwater tank reset button will not reset, why?
I've reset this button twice prior, turned down the temp, the button will not reset now, can you help me?
4 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Intermitent heat from Atwood 10 gal marine water heater
Water level safety shutting down heat source
Posted on May 24, 2009
heatman101
  • 43501 Answers
SOURCE: I put a new top
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Posted on Dec 05, 2010
  • 5089 Answers
SOURCE: reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else c
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Posted on Oct 07, 2012
Tip
Rest Electric Hot Water Tank Thermostat
I understand that you need to reset your hot water tank thermostat. Here are some instructions for you to follow with visual aids on what you are looking for and what you need to rest.
First you must locate the thermostat in order to rest it. There are usually two service panels on a hot water tank. The service panels look similar to the ones in the picture below.
justinbur167.jpg Once you locate the service panel(s) you will need to remove the top on and locate the thermostat the reset should be in the top one. You will be looking for the button that is located in the middle of the thermostat. This button will need to be pushed down firmly. The rest button is often red however; it comes in many different colors, shapes and sizes.
If the thermostat rest automatically pops back up then you will need to replace the thermostat. If you do not hear the heating elements heating up like in your coffee maker her the noise of the elements heating. You may have a bad element or thermostat of even both may be bad. The cost of rebuilding a hot water tank is cheap compared to replacing so I would suggest rebuilding. This is a pretty easy task that you can also receive help from FixYa for.
Hot Water Image: visualdictionaryonline.com: Copyright QA International 2011
http://www.bing.com/images/search?q=electric+hotwater+tank+&view=detail&id=947D2952ACE0C75D1DCEDB6216D99F764F1F2DB1&first=31&FORM=IDFRIR&qpvt=electric+hotwater+tank+
on Apr 09, 2011 | Water Heaters
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
Turned down temp on Water Heater a little, and now we are not getting any hot water. Not even Warm. Whats wrong?
For electric tank: Push in the reset button located on upper thermostat.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
For gas tank, then more specific information might be needed for example if unit has power vent, when was the air intake cleaned, is the pilot lit, what brand and model number etc etc..
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
For tankless, or solar, or hybrid electric, gas boiler, or indirect, or RV heater, etc then please include brand, and model that appears on label on side of unit.
Sep 05, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 82vr52-2 water heater, I need to do a reset , Can you help me ?
Hello Gwest rxshaw,
I understand that you are having a problem with your Hot water heater and need to reset the thermostats on it. The hot water tank that you have has an upper and a lower element the upper thermostat has the reset in most cases. I will try to walk you thru it.
1. Remove the upper service panel on the side of the tank
2 You will see the black thermostat it has a plastic cover over it and has wires running form the top of the tank to it and wires running from it down ward toward the other service panel. Do not remove the plastic cover as it does not need to be removed and lessens the chance of getting shocked.
3. Locate the dime size red button in the middle of the thermostat press it down and release
4. Listen to the hot water tank you should hear it heating up if the rest worked.
Below is a picture of the thermostat and red button that you need to push.
thumbnail.aspx?q=553552980120&id=f9aa5840c8a1e1de886a4ea3131a35b0 If resting the hotwater thermostat does not work you will need a volt meter with continuity and will will go to the next step and check the elements and the thermostats to see if they are bad. Post back to this thread so I may assit you further.
Thank you for Choosing FixYa.com
Justin
Apr 09, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 83xr52-2 50 gal residential water heater. Water temp was low. I cut power at electric panel, removed upper panel on water heater, turned up thermostat, replaced panel and switched power back on at...
You can open the top up again. I would not turn the temp higher than 130 degrees, maximum. However, there should be above the thermostat a red button. This is where the power wires connect to the thermostats and heating elements. Sometimes this button needs to be reset, press it and discern if you hear a click sound. This means that the high temperature safety switch has tripped open and you had to manually "reset" it. There are two thermostats by the way. The water heater usually works this way. There are two thermostats and two heaters. The upper tank heater turns on first and it heats the top half of the tank. Then when the thermostat above is satisfied it then allows the bottom heater to come on and heat the bottom half of the tank. You might want to set the bottom heater thermostat as well. This is made this way because it is actually faster and more efficient to heat the top half first and the bottom half secondly. Try this first with the reset button. We could check voltages, but that requires a level of knowledge and safety that I am not sure that you are comfortable with. Pictures of the upper and lower thermostats and connections will help if the "reset" does not do the trick. By the way, not meaning or implying anything, but did you move the thermostat in the right direction? Sometimes the dials can be confusing.
Nov 28, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have hotwater in the tank but none at the faucets.
By-pass may be faulty. Are you getting good pressure on hot side, even though not hot?
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Water Heaters Logo
14 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
