Question about Samsung YP-U2 MP3 Player
Sec-ypu2(b) - Samsung YP-U2 MP3 Player
Evaluate 88ft/sec*1mile/5,280ft*3,600sec/hr
Take it in two steps.
Multiply 88 ft / sec by 1 mi / 5280 ft to get 88 ft*mi / 5280 ft*sec. 88 / 5280 is 1 / 60 and ft*mi / ft*sec is mi / sec so it simplifies to 1 mi / 60 sec.
Multiply 1 mi / 60 sec by 3600 sec / 1 hr to get 3600 mi*sec / 60 sec*hr. 3600 / 60 is 60 and mi*sec / sec*hr is mi / hr so it simplifies to 60 mi / hr or 60 mph.
Mar 04, 2013 | Cars & Trucks
What does diagnostic code lf mean
1blink/sec---normal, 2blink/sec--blown fuse--3bliks/sec--replace evaporator sensor,4blinks/sec--mode switch failure, replace board,5blinks/sec--pot. failure,replace board;6blinks/sec--bad thermostat input; 7blinks/sec--factory only;8blinks/sec--bad room thermostat. The blink pattern repeats every 5 seconds.
Jan 13, 2013 | Amana PTC153B35AJ Air Conditioner
My YO-U2R Mo3 player doesn't work. its not switch on. once i didi format. please answer
Try resetting the Mp3 player. You might a tiny hole on your player for reset, you can use office pin and reset. You can visit manufacturer's website and check on FAQ http://www.scribd.com/doc/62999/SAMSUNG-MP3-YPU2-MANUAL
You can also upgrade the firmware of the player from the manufacturer's website.
Aug 18, 2011 | Samsung YP-U2 MP3 Player
No ring on lines on extension 11 and 12. How do I program to ring?
Please follow the steps given below
To set distinctive ringing
1. Press #9876 to enter User Programming Mode
2. Press a Line or extension button. The LED is steady green.
3. You can press Hold to switch between internal and external pitch.
(Internal = station calls within your system; external = outside line calls.)
4. Enter the two-digit pitch number (see table)
5. Press the same button that you pressed in Step 2 (Line or extension). Two beeps is a confirmation tone and “DATA PROGRAMMED” displays on your LCD.
Tone No.                   Frequency and Cadence
 01
     500 Hz 1 sec. On, 3 sec. Off, repeat
02           300 Hz 1 sec. On, 1 sec. Off, repeat
11          500/640 Hz 1 sec. On, 3 sec. Off, repeat
12          500/640 Hz 1 sec. On, 1 sec. Off, repeat
13           860/1180 Hz 1 sec. On, 3 sec. Off, repeat
 14         860/1180 Hz 1 sec. On, 1 sec. Off, repeat
15          1300/1780 Hz 1 sec. On, 3 sec. Off, repeat
 16         1300/1780 Hz 1 sec. On, 1 sec. Off, repeat
17          860/1180 Hz 0.5 sec. On, 1300/1780 Hz 3 sec. Off, repeat
18          860/1180 Hz 0.5 sec. On, 1300/1780 Hz 1 sec. Off, repeat
Thanx
Jul 22, 2010 | Toshiba DKT2010SD Phone
Which is the latest ypu2 firmware?
Support site for sub type yp-u2:
http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=YP-S3&dType=D&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-S3
Scroll down and select the exact model: A page with
manual> software> firmware> will show up.
At last check for the description of the latest firmware upgrade.
Sep 05, 2009 | Samsung YP-U2 MP3 Player
Help
sec^4X- sec^2X = 1/cot^4X + 1/cot^2X
RHS
1/cot^4X + 1/cot^2X
=1/(Cos^4X/Sin^4X) + 1/(Cos^2X/Sin^2X)
=Sin^4X/Cos^4X + Sin^2X/Cos^2X
=Sin^4X/Cos^4X + Cos^2X.Sin^2X/Cos^4X
=Sin^2X/Cos^4(Sin^2X + Cos^2X)
=Sin^2X/Cos^4X
=(1-Cos^2X)/Cos^4X
=1/Cos^4X - Cos^2X/Cos^4X
=1/Cos^4X - 1/Cos^2X
=Sec^4X - Sec^2X
=LHS
Feb 02, 2009 | Super Tutor Trigonometry (ESDTRIG) for PC
What is the range shutter speed?
The DiMAGE A2 controls shutter speed in the range of 30 sec. to 1/4000 sec. in 1/3 increments. (at bulb maximum 30 sec.) The speed, 1/4000 sec. is controlled only when the aperture is f5.6 or over in P and A mode. The highest speed in S and M mode is 1/2000 sec. The lower range depends on the set camera sensitivity. ISO800: 4 sec., ISO400: 8 sec., ISO200: 15 sec., ISO100 and ISO64: 30 sec.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
How many images can the DiMAGE Z5 save in a 16MB SD Memory Card?
Still image Image Size: 2560x1920/2048x1536/1600x1200/640x480 Economy : 18 / 26 / 37 / 142 Standard : 9 / 15 / 22 / 101 Fine : 4 / 7 / 12 / 67 Movie 640x480 Fine: 30 fps: 9 sec. / 15fps: 18 sec. 640x480 Std.: 30 fps: 14 sec. / 15 fps: 28 sec. 320x240 Std.: 30 fps: 29 sec. / 15 fps: 57 sec. *The writing speed of the memory card may prematurely end the recording of a movie clip.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Samsung YP-U2 MP3 Player Logo
64 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
