Intertherm water heater Model: IN140DHMSE4, it has two temp settings, but the restet switch is on the top temp setting, & I reset it twice & now it will not restet, why?
I reset it twice prior, but today it will not reset, can you tell me why?
Buffalo12980
  • 625 Answers
SOURCE: Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Posted on Dec 14, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Intertherm gas furnace model number m6bb070abfc01
Sounds like there is no signal from the thermostat. Take a jumper wire and place it on the R and W terminals in your furnace. Make sure that the door switch is taped down. This should start he burner. If it does, start looking for a blown fuse, bad transformer, bad thermostat or a break in the thermostat wire.
Then take that same jumper and jump out the red and white wires leading to your thermostat. This may help to rule out the thermostat.
Posted on Dec 26, 2007
hotuna
  • 288 Answers
SOURCE: heater won't come on when temp drops...must reset limit switch every time.
The limit switch is shutting off and you are having to press the re-set button, right? The limit switch, if I am understanding you correctly, is the thermal disc type, may be ok, but what is causing it to shut off? I would first, not put total faith in the serviceman (PG&E maybe) and replace the limit switch. Its only a few bucks,and easy to do. Then if its still the same problem, look into the venting pipe. As it may not be adequate for the heater. Espically if its new. These new wall furnaces are kind of touchy. It may be larger, BTU wise, and the vent pipe may need to be enlarged. If this is a big job, and a bit too impractical, check the vent pipe, make sure its in good conditon, no leaks ect. install a cO2 detector and by-pass the limit switch.
Posted on Jan 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: how to restet my sansa e260
Menu - Settings --> Reset All
This option will reset all the Sansa e200 player’s settings back to
factory defaults.
Posted on Jun 13, 2008
chillmaster
  • 104 Answers
SOURCE: i have a 30 gal.
usually there is a long mark on the dial just ahead of A. the mark is 120, a is 130 b is 140 and c is 160
Posted on Jun 30, 2008
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
Not heating up water, has power to it and have temp. set at about 135 deg. is there a reset button on it could not find it.
Water heater is not identified.
1) Add a comment with model, brand and energy-type for possible help.
2) Electric tank-type water heater has ECO reset button located on upper thermostat under the top cover.
See images:
http://waterheatertimer.org/images/water-heater-thermostat2.jpg
http://waterheatertimer.org/images/Jly-022-thermostat2-175.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Gas tank-type ECO varies by brand and model of water heater, and specific identification of gas valve is needed before listing the possible things to look for.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
4) Tankless water heater. I suggest calling manufacturer before tearing water heater off wall and throwing away.
Sep 26, 2011 | Water Heaters
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washer will not fill up with hot water however it will with warm
Is your water temp on your water heater set high enough? If it is sounds like you are getting water from both hot & cold water valves. If temp is set correctly on machine temp switch may be bad on warm all time.
Mar 12, 2010 | Kenmore Washing Machines
The sensor light is blinking twice which according to the info is
you have the button set on vac switch to higher level
Jan 18, 2009 | Water Heaters
Water Heater Heating Problem
i guess it is electric ,check bottom element reset button .remove bottom cover with power off look for a button on bottom thermostat or limit if find push it to reset ,,then set the thermostats , set top to desired temp and the bottom at least 10 degrees more ex. top 130 bottom 140 this might prevent problem reoccurring if this not problem bottom element could be burned out.replace ele
Nov 30, 2008 | Water Heaters
I have a 30 gal. hot water heater the temp settings just show a b c i was wondering what the temp of those are
Jun 30, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
