Question about Simpson Esprit 750 Top Load 7.5kg
My Simpson Espirit 750 won't wash but spin is OK.
Replaced the reverse forwarding module with the new replacemant one 628-200-105 and wired it according to instructions given. Still won't wash. If anything it is moving real slow in the wash cycle. I have checked online and am thinking that maybe I should replace it with the new part no. 0628271101. The one that was sent to me was 628200105. Are these same and interchangable?
2 Suggested Answers
tanda400
  • 7 Answers
SOURCE: simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
Posted on May 04, 2012
Hi, I am Hoping for a Service/Repair Manual for a Simpson Espirit 450 Top Loader. I think it has Shorted out and needs rewiring or a fuse replaced(If they have Fuses)
I went google and typed in-- workshop manual for simpson espirit 450 top loader washing machine -- and got several pages one of which is www. manuals. club
I suspect that you may have to pay for the manual but on their page there is a listing for user manual, installation manual, service manual, parts list and schematics
try and see if you get what you want
there may be a loose connection to the program board or a faulty program board but I doubt that you will need a rewire or anything drastic like that
Dec 07, 2015 | Simpson Washing Machines
My washing machine spins but doesnt complete the spin cycle
does it drain all the water out/ If not then check your pump filter.
Oct 04, 2014 | Simpson Esprit 750 Top Load 7.5kg
I have a Simpson Ezi Set 450 top loader washing machine which doing everything else although it will not agitate, why?
Fairly common issue. Motor control module is shot.
You can get them from your local parts shop, or ebay.
Sometimes they are direct swap by the big plug, sometimes there is slight rewiring required (wiring diagram comes in kit and they are just spade connectors on to the timer, no splicing or anything).
If you take the top panel off and it does not have a module exactly like in the pic on ebay, make sure you are happy to do the wiring bit before buying (easy if you can read a simple wiring diagram)
http://www.ebay.com.au/itm/0628271101-NEW-Simpson-Hoover-Reversing-Motor-Control-Module-GENUINE-/201054721557?pt=AU_ApplianceAccessoriesParts&hash=item2ecfcb9615&_uhb=1
May 26, 2014 | Simpson Washing Machines
Simpson espirit 750 won't turn on
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Hot water selection not working on Simpson espirit 750 model22S750, Serial 322 21271
Might be the solenoid valve . Remove the solenoid valve and replace it with a new one. If not that it could be the electronic . If you know what to do and can use a volt meter you might try testing for voltage at the valve to see if the electronic is working. Don't forget to check that the voltage goes away when the cycle is on spin as the electronic triac could be faulty too. Hope you can get the idea what to do from this www.appliances.cjb.net for further assistance 'contact me'
Mar 05, 2011 | Washing Machines
Operating instructions for 36P450 Simpson washing machine
I have a Simpson espirit 450 andthe agitator has a hole. I have beensent a new one but have no idea how to remove the old one. I can loosen the bolt at the bottom but can't can remove the bolt. Unsure why or what to now ? Would love some help... Thank you
Dec 01, 2010 | Washing Machines
Simpson eziset 750. During the wash cycle, it does not agitate in both directions, it will only turn in one direction, then stop and pause like it wants to turn in the opposite dirction, then turns in...
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Oct 14, 2010 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
My simpson espirit 700 has been in storage for
check first the continuity of the power cable. next is the fuse if it is not busted. then try to open the control portion there might be some coroded contacts.
Apr 07, 2009 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Vernon Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
