Question about Logitech X-230 Computer Speakers
Can I use Logitech x-230 speakers without the sub-woofer?Any suggestions? I only have the 2 speakers.
2 Suggested Answers
SOURCE: Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Posted on Jan 18, 2012
Do i have to have the sub-woofer in order for my logitech X-230 speakers to work with my computer?
Certainly any large speaker itself cant be used with
very weak computer out signal
The signal should have power amplification in addition to
voltage amplification to energise large speakers
Oct 09, 2012 | Audio Players & Recorders
Jan 18, 2012 | Logitech X-230 Computer Speakers
Where can i purchase the audio cables that connect the Logitech X 230 sub woofer to my laptop and mp3 player
Usually you can purchase audio cables for speakers and sub-woofers from any or authorized PC outlets.
Just explain to the dealership what you want to connect it to and they will shoe you the right "jack" to buy.
G.
Nov 01, 2011 | Logitech X-230 Computer Speakers
Only have the sub itself, Can I still use it and if so how?
Unfortunately you will not be able to use the sub-woofer by itself because the input for the Logitech X-530 has a special cable to connect to the sub-woofer. You could always try looking on eBay or Craigslist for replacement parts.
Aug 18, 2011 | Logitech X-530 Computer Speakers
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
How do you connect logitech speakers on the pc
1) plug the cable coming out of the satellite with the sub-woofer at the reat 2) plug the 3.5 cable jack coming out of the second satellite to the computer audio out ( generally green color connector ) connect the power adapter with the sub woofer
and you ready to enjoy the music. make sure yo switch on the the power adapter.
Oct 22, 2010 | Logitech R-20 Computer Speakers
Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at ben.petrofsky@live.com?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Apr 02, 2009 | Logitech X-230 Computer Speakers
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
No sound out of woofer
Hello sparkie102
Happy Holidays
you have to check if all the cables are well connected, and in the right inputs. 2) check your software for sound that is enable, fine.
turn up the sub volume , if got it independent.
other that this, is a failure sub. if got warranty, use it! or RMS your sub.
Dec 26, 2007 | Logitech Z-2300 Computer Speakers
Shorted Sub-woofer
try this site first; http://logitech-en-amr.custhelp.com/cgi-... but it sounds as if something has fried in the amp - if you look inside you may well see some burning marks around some of the components. Another possilility is that the cable being pulled out pulled something inside the speaker that has damaged the cone or more likely the power supply , but the symptoms you describe suggest an amplifier issue, possibly caused by damage to the power supply system. Hope this helps :)
Mar 07, 2007 | Logitech Z-560 Computer Speakers
Logitech X-230 Computer Speakers Logo
56 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
