Question about Ovens
Jenn-air 8114p955-60 Door won't close
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Jenn-Air Expressions Mod. W30400BC
no adjustments hinges are mounted inside door panel right?check to make sure theres no damage to inner door panel
Posted on Mar 04, 2008
reg501
  • 413 Answers
SOURCE: jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Posted on Jun 10, 2008
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
  • 949 Answers
SOURCE: Oven door falls open and will not close tight on
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
Posted on Jul 24, 2010
Door will not close all the way...
This is likely one of two problems. Either the fiber gasket is getting in the way or if it is like ours one of the hinges is broken or bent. The Hinges can be replaced for about $13 a piece and is not a difficut job. On our the oven was also opening more then 90 degrees and wouldn't close more then to about 1.5 inches away from full closure.
Jan 09, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
One of the oven doors does not close tight so heat escapes. It is a Jenn Aire electric double wall oven model number JJW9627DDS.
Sounds like the oven door hinges have worn. If door is not obstructed in any way and will fully close when pushed but open about half a inch when released then it will be the hinges. Not sure of cost of spairs. I believe this to be a John Lewis Model. If it has a Enr no inside the door or inbetween the door hinges then I could give you price on spares
Nov 15, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
Aug 02, 2008 | Jenn-Air JJW8330D Electric Single Oven
Jenn air oven stuck closed after attempt to activate self-cleaning
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Mar 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
