Question about Mitsubishi VS-60607 TV
Fluttering and picture discoloration
When we first noticed the problem a black section of screen would appear on the top and bottom of the screen and disappear after the tv warmed up. Now the fluttering bounces through the entire screen and the discoloration are in shades or either red, green, or blue. My husband has taken off the back panel of the tv to see if there might have been an adjustment he could make but wasn't able to find any. The discoloration happened after he used a flashlight to get a better look at the components on the circut boards in the back of the tv. He didn't touch anything just looked around. If anyone can point us in the right direction of fixing the problem we would be very greatful.
Re: Fluttering and picture discoloration
Model # VS-60607 Mfg Yr February 2000 Big Screen TV:
1.  tearing/fluttering/ripping across entire screen caused by damages associated with diode 522, and;
2.  the problem is really an OEM Mitsubishi causation as the
leads of said diode get too hot <too much current flowing through
it> and this component lifts itself off of the main circuit board, &;
3.  supplemental hidden damages arise from this, and;
4.  you should not attempt to fix this set but rather contact the
national & state Consumer Protection staff & file a complaint, &;
5.  pleadings should say:
    a.  this set almost burned down our/my home & us to death;
    b.  we paid too much money for this to happen, and;
    c.  we demand full replacement of the set & money for our
         inconvenience for all of the above, and;
    d.  said replacement need not be a Mitsubishi but like unit;
6.  check with Martindale-Hubble to find a good law firm/lawyer.
7.  have fun, eh!
Posted on Oct 14, 2007
0 characters
3 Points
What can be done to repair picture to my TV
Vertical scan output section circuit should be checked. Contact any service technician.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Jul 01, 2008 | Sony KV-32FV27 32" TV
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Adjust manual picture on TV
Sounds like you may have caps going bad . Adjusting may tend to only stretch the the picture too much . Also when you say horizontal are you saying the top and bottom are closing in ? If yes then your problem is in the vertical section . If side to side then check the horizontal section . Good luck
Mar 01, 2008 | Standard (CRT) Televisions
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Standard (CRT) Televisions
Picture quality
your problem is in vertical section 1 check for proper supply. 2 some capacitor in that section is faulty. not a major problem. it is COMMON PROBLEM can be fixed easily.
Sep 24, 2007 | RCA F36650 36" TV
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Mitsubishi VS-60607 TV Logo
159 people viewed this question
Top Mitsubishi Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Mitsubishi Standard (CRT) Television Expert? Answer questions, earn points and help others
