Question about Bosch 500 HMB5050 Microwave Oven
Bosch bhm5050 trim remove
How do you remove the trim on the outside of a built in Bosch microwave HMB5050
3 Suggested Answers
SOURCE: My Bosch microwave (built in
I have the same issue, plus mine shuts down after 30 seconds. There are a few other similar issues on here, with solutions including unplugging it for 10 seconds, replacing a fuse, and replacing half the internals. Please post your fix if you find one!
Posted on Aug 01, 2011
SD Tech
  • 14553 Answers
SOURCE: bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Posted on Dec 10, 2012
Bosch microwave door sags. It's difficult to open, close or start. Can it be adjusted?HMB5050/01 Photo is of right lower corner of door showing the misalignment
Any microwave with a mis-aligned or loose door is probably leaking excessive microwave energy, and should not be operated unless a leak test is conducted using a calibrated meter.
Unless you own such a meter, the oven should be inspected and repaired by a qualified technician.
Jul 26, 2016 | Bosch Microwave Ovens
Bosch microwave door sags. It's difficult to open, close or start. HMB5050/01
I would say the hinged are loose and misaligned.
Contact me at http://www.microwavecontrol.com if you have other questions.
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Bosch hmb5050 shut down after 30 seconds
Dec 10, 2012 | Bosch Microwave Ovens
Why does the microwave shut off after 20 seconds
This indicates a problem in the keypad control board, defective thermal fuse, or a partly shorted magnetron, "gets to hot" this will require a professional to assess the situation.
Mar 27, 2012 | Bosch 500 HMB5050 Microwave Oven
No power at all
check plug fuse,if thats ok,there should be another fuse inside on the power supply have that checked out
Aug 14, 2011 | Bosch 500 HMB5050 Microwave Oven
My Bosch microwave (built in HMB5050 has stopped heating all of a sudden. Everything else appears to work fine but it does not heat. What is the problem?
Jul 28, 2011 | Bosch 500 HMB5050 Microwave Oven
Bosch 500 HMB5050 Microwave Oven Logo
41 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
