Question about Bose Lifestyle V25 Theater System
Volume goes up by itself
I have Bose V25 home theater system. Volume goes up by itself and it will get stuck at 100 ( max volume). Now this issue happens 5 - 6 times in an hour. Neither the volume control on remote nor on the receiver will respond at this time. I Have to power it off and then power it on after 10 - 15 minutes to set the volume at the desired level. Pleasae help !
    Problem Solver:
  • 5 Answers
First, check your software firmware version and see if there is an update. If available read your manual how to do a firmware update using your USB port, if you don't have a manual, check Bose.com for their online manual and firmware updates. I had a different problem but the firmware update solved it. Another tip to increase the depth of your bass, while doing the adaptiq process, cover your bass speaker with a pillow, this will make your bass more deeper. You need a second person to cover your bass module with a pillow. in this way, the adaptiq process cannot hear the bass sound and it will increase the bass. You might need to do this several times until you get the desired bass sound. If you have not setup using adaptiq, your better off not using adaptiq, the sound is much better. Hope this helps.
Posted on Nov 18, 2013
4 Suggested Answers
SOURCE: VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Posted on Jan 16, 2008
SOURCE: Bose 321 System Stuck on Hotel Mode!
Hey, try this out
-Press Enter and On/Off on the media center , on standby mode
-now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON
- on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off.
Thanks
Brigade
Posted on Nov 08, 2008
  • 7 Answers
SOURCE: volume
I had this problem and checked the main wire going from console to bass unit, it was loose from where I had moved the unit to insert another device (RCA Jacks). Apparently if the wire from the unit is loose, it over - rides the volume and by default adjusts it to 30. Additionally, I reset the system console and bass unit console, during this process. Try this, it might fix your problem.
Posted on Jan 02, 2010
Bose system is just over 1 yr old, hooked up to Smart Tv ( same age) sound was working fine, turned volume down, no sound at all after that
Hi, You have a Bose Home Theater System hooked up to your television and I'm wondering if you're controlling the volume through the Bose Home Theater System or the television because both have a volume control and if you have the television volume turned down and you're using the Bose Home Theater System for volume or visa-versa then you're not going to get a decent sound. I hope you know what I mean...... CHEERS..
Mar 31, 2016 | Bose Audio Players & Recorders
Volume
Heyya first check out the speaker wires and then try
Dec 03, 2007 | Bose Lifestyle 28 System
Volume control stuck
Hi Jenny,normally to resolve the problem you are experiencing,I strip the volume control and service it.You need to take it to a technician to have it repaired.Thanks Ravi
Nov 21, 2011 | Panasonic Home Theater System System
I have the lifestyle v25 system but my wife does not want to use the bose sound all the time. She says she doesn't need 5.1 when watching hgtv. Can you help.
Help how? Change her mind?
If the TV has speakers and IT has basic audio coming in directly from your (presumed) Cable Box, use the TV speakers.
May 25, 2011 | Bose Lifestyle V25 Theater System
The sound/volume is not working properly on our Bose 321 system...i.e., whereas, a "normal" volume at (let's say) 35-40 is way loud, but now have to turn volume up to 100 (maximum) to be able to...
Make sure the device it is connected to has its audio properties setup correctly. If this is a cable or satellite box, most of them have a volume output level. Changing this will change overall volume.
Mar 01, 2011 | Bose 3 2 1 GSX System
Bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
Aug 02, 2009 | Bose (321GS) System
Bose 321 system - volume is stuck at 30
You'll need to go into the main menu and there is where you can change your on volume, minimum volume, and maximum.
Apr 02, 2009 | Bose (321GS) System
Hey, try this out
Thanks
Brigade
Sep 25, 2008 | Bose 3·2·1 II System
VOLUME ISSUE
Dec 28, 2007 | Bose 3 2 1 GSX System
Bose Lifestyle V25 Theater System Logo
282 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
