Question about Samsung DMR78AHS Builtin Dishwasher
Samsung DMT400RHS Leakage error
Nothing is happening, unplugged unit still didn't reset? Any ideas what I can do other than calling repair man?
  • 1,869 Answers
Check you house circuit breakers if you have no lights and the DW is plugged in next check to see that the door switch still locks the DW shut otherwise;call a serviceman
Posted on Nov 18, 2013
Have over lever water error on samsung dishwasher
Your: Have over lever water error Probably means over level? In other words water is too high I would guess. Sounds like you have a bad water level sensor, or connections from or to and from or to the "brain" I'd unplug to reset the "brain". but it that doesn't help it's probably service tec time. Ask to estimate the price.
Mar 04, 2015 | Samsung DMT400RHS Builtin Dishwasher
How to reset dmt400rhs
What do you mean "reset" ? Do you mean cancel a cycle, drain out the water, and shut down? If so, hold the START button down for 3 or 4 seconds.
Aug 25, 2014 | Samsung DMT400RHS
Samsung dmt400rhs blinking HEAVY light
I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Jul 09, 2014 | Samsung DMT400RHS Builtin Dishwasher
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
Low-level water level error DMT400RHS
We took off the left side bottom and the float was stuck on ours. We bumped on it on the very bottom plastic while it was feeling up with water and the float flew up and now its working. We gonna let it run its course then clean it out where float is to make sure it doesnt have any more residue or gunk in it.
Sep 26, 2012 | Samsung DMT400RHS Builtin Dishwasher
When the air conditioner goes on it shows "E2"and nothing else happens what can be done to solve the problem?
The E2 Code, indicates a Sensor or System Failure, But, before calling Haier, try this.
Turn the Master ON/OFF Switch to OFF & unplug the unit for 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the unit's electronics during that 15 minute timeout, have reset itself and reverted back to the original factory settings. If so, it was a false code. If it didn't reset itself, contact Haier Customer Support 1-877-337-363.
Hope this helped you. Please let me know.
Jul 07, 2011 | Haier Heating & Cooling
After a brown out, the front panel shows 88 and 08 (flashing). Nothing happens when i press any of the buttons. The refrigerator seems to still be cooling.
Wow, Grumpit...your solution worked perfectly (Press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.) What a racket both GE and local repair places have going...they both told me I needed to replace the entire contol panel!! GE needs to start telling people this along with unplugging the fridge when you call in and ask about the error code.
Jan 04, 2011 | Samsung RF267AEBP (258 cu ft) Bottom...
Samsung double door refrigerator/freezer is not holding the tempature in the refrigerator. When you attempt to reset the temperature and press "power cool" nothing... temp remains around 56 The freezer...
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Jun 15, 2009 | Samsung RS2556 Side by Side Refrigerator
Error code
be certain you have it plugged directly into a ac socket , no surge protector or gfic protector.
the main fan should have come on first then the compressor.
if not the fan capacitor or the fan is stuck.
try reseting it by
for resetting the error code. Unplug unit, clean filter, HOLD DOWN power button and CONTINUE HOLDING while plugging unit back in. Unit will beep. Unplug again, plug back in and resume normal operation
Mar 30, 2008 | Windchaser PACR10 Portable Air Conditioner
Samsung DMR78AHS Builtin Dishwasher Logo
188 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
