Question about Bose Audio Players & Recorders
What does LTE do on my subwoofer
Movie voice sound to base heavy and explosions sound dull also voices aren't loud enough I dial it up to 55 to hear the actors
5 Suggested Answers
SOURCE: Sound from DVDs
check the centre speaker is wired right
Posted on Jun 27, 2008
cjackHD
  • 71 Answers
SOURCE: when watching a DVD, the surround sound plays all
If there is nothing at all from the center channel while watching a DVD, first try resetting the system (unplug the power cord from the sub, and the DC power cord from the media center for 30+ seconds) If a reset doesn't help this, run the "adaptIQ" setup disc again. Honestly, this is a very odd problem for that system to have. (especially since we know the center speaker works for other sources) I hope this helps.
Posted on Jun 22, 2009
lock123
  • 6831 Answers
SOURCE: when playing a movie i can hear the music but
Hello
OK, you will need to have a look in the sound menu to change the channels trough which the movie is being played. Have a look on your remote, if you cannot find it, press menu and scroll to the sound menu.
This is only a setting, so do not worry, if you cannot find it yourself, you will be able to download the manual HERE.
Kind regards
Andrea
Posted on Aug 13, 2010
  • 144 Answers
SOURCE: when a movie is playing, you can hear all sounds
The voices are probably coming out on one of the channels that has a bad speaker, bad wire, loose connector, or bad output. If you have the audio set to 5.1 output, change it to two-channel stereo output. The voices should return to normal.
Posted on Nov 03, 2013
How do I manage overpowering tv background noise
I think a surrond sound system helps. I have the same problem, i can't hear dialogue either. I can't afford surround sound system so i have to keep turning volume up & down accordingly.
Jul 31, 2014 | LG 55LV5500 55 Class 1080P 120Hz LED TV...
The camera did not record voice of movie when I use the optical zoom
From page 80 of this manual: "Optical zoom blocks sound being recorded when zooming."
Many cameras do this as otherwise the recording will include the sound of the lens being zoomed. There are two possible workarounds for this: 1) Don't use the optical zoom while recording. 2) Use an external sound recorder to record the soundtrack and mix them together on the computer.
Mar 10, 2013 | Fujifilm Finepix T400
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 18, 2011 | Plantronics CS70 Wireless Headset
My subwoofer keeps making a clunking noise...How do I correct this problem?
The clunking noise could be the voice coil maxing out hitting its stop or a warped voice coil. How much power is going to the subwoofer. If it only happens when the high volume setting it and not at medium volume the subwoofer may not be able to handle the power. With your hand gently push the speaker cone back and release the cone so it can return to its rest state several times. Do you hear a scratching sound or feel any resistance? If you do your voice coil is damaged if not from physical means it could be from the voice coil overheating. If it is OK shake and rap on the subwoofer box and try to identify any loose parts which could be making noise.
Aug 13, 2010 | Denon Audio Players & Recorders
Cannot hear callers voice during a call but caller hears mine
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear speaker.you can do your self just watch video on online.
Dec 29, 2009 | Nokia N72 Cellular Phone
Rattling sound with any significant base output
You either ripped your voice coil, or you have something jumping around inside (Screw, nail, etc.). You can tell of a blown speaker by pressing straight in, and if you hear a rubbing noise, then your speaker has disconnected from your voice coil. Mickey mouse jobs include Krazy Glue, but It's touch and go
Sep 02, 2009 | Sunfire True Sub Signature Subwoofer
Speakers won't play ''loud at all '' Just Very faint
they dont sound loud because you need to use the DUAL voice coils and make it 2 Ohms. Google " how to bridge a dual voice coil sub"
May 25, 2009 | Infinity Reference 1052W Subwoofer - 10"...
Microsoft Digital Sound System 80 - Parts
Same here!
Silicon seal fixed for a while ... ripped again 3 months later.
Apr 05, 2008 | Audio Players & Recorders
I can't hear voice
chek sound settings and sound level. thts very common. no problm with phn
Jan 13, 2008 | Motorola Mobility E680 Handheld
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
27 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
