Question about GE Monogram ZIR36NMRH Refrigerator
Evaporator coil frost buildup
The coil inside this refrigerator only unit frosts up. sometimes an inch of ice can form
dididsaythat
  • 291 Answers
SOURCE: Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Posted on Aug 28, 2007
SOURCE: refrigerator keeps running
I have the same problem. I called a service rep for G.E. and he said that there are 3 thermodisc
sensors behind the white evaporator cover. He gave me a price to repair that was completly out
of range for the problem. I paid him for his service call and sent him on his way. I then decided to
to order the parts from a factory online parts center at less then half the cost of my estimate not
to mention that when I was ordering the part the Factory emailed me a complete parts breakdown showing the Thermodisc and that my unit only has 1 thermodisc not three installed from the factory.
I ordered 2 one for a backup just in case. I deiced the buildup and installed the disc after 24 hours the refrigerator was working normal for about 4-months. Once again the refrigerator iced up and stopped cooling so I called the factory tech support and they told that it is normal to have some ice on the cover of the evaporator and the thermodisc is at that point supposed to open the cooling circuit to let the unit go into defrost mode and then close again. The Tech said that I had a bad
Thermodisc again so I put the spare one that I ordered in and it also worked for about 3 months
now I have the same problem ????????
Brad
Posted on Sep 14, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
aasc
  • 1606 Answers
SOURCE: frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Posted on Oct 02, 2009
  • 534 Answers
SOURCE: frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Posted on Oct 06, 2009
Why is my ge refriderator "frost-free" freezer frosting up?
most likely the defrost heater behind the panel thats frosted up is burned out so it cant defrost the unit,g.e. is notorious for this,remove this panel inside the freezer and remove 2 screws at the bottom of the evaporator coil holding the heater to the evaporator and unplug it the new part number is g.e. WR51X10055
Jul 23, 2012 | GE GSH25JFT
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
The ice maker is not working and the freige is not getting cold. everything is defrosting
first check the inside rear wall of the freezer for frost buildup,if the wall is frost covered remove this cover and defrost the evaporator coil,then remove and replace the heater located under the coil,if no frost on this wall,then replace the ptc overload relay on the compressor as this will be your problem
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Ice forms at the bottom of freezer. I have defrosted and cleaned ice, but the drain doesn't drain. Is the drain plugged and if so, how do I clean it?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 14, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker leaks and ice forms in bottom of freezer compartment, water runs out onto floor
Feb 08, 2011 | LG LRFD25850 French Door Refrigerator
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator not cooling freezer works fine blower motor in rear of unit on but turning slowly
Since the freezer is fine, you are in good shape. Pull off the back cover inside the freezer to inspect the evaporator coils. You should see a light frost pattern. If it is heavily frosted, then you have a open heater element - located at bottom of evaporator. If heater is good and you have heavy frost buildup, replace motherboard and thermistor which is clipped to the top of the evaporator.
Oct 01, 2010 | GE GSS20IEP Side by Side Refrigerator
FREEZER AND REFRIGERATOR NOT COLD
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan behind the rear cover inside the freezer is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). heavy buildup of ice (defrost problem)
Aug 19, 2009 | Refrigerators
Ice forming on bottom of inside of side by side AMANA refrigerator / freezer and leaking on floor
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 18, 2009 | Refrigerators
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
GE Monogram ZIR36NMRH Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
