Delta DTA Remote control will not turn off the TV or adust the volume
I have just e]set up the new rogers Digital convertor. I can get channels but not these other things
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: trying to find comcast digital code to use their
10250
Posted on Jun 16, 2009
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
I have 37LC50CB LG tv. When I turn on with new DTA remote control come up channel # 56-1 and cloud(nothing) on screen Then I...
Your DTA remote cannot turn on your LG TV. Find the red/white/yellow cable that was in the box with your DTA and connect it between the appropriate RCA outputs on the rear of the DTA and the corresponding RCA inputs on the rear panel of your TV. Disconnect the cable connected between your DTA and the antenna input of your TV. Be sure your DTA is on. Turn on your TV and select your DTA as the input source. You may have to press SET UP on your DTA remote to display the set up screen on your TV. Do a channel search and you should be all set.
Nov 24, 2016 | LG Televison & Video
Have an Element TV and the remote will shut the TV off and on plus do the SAT/CAB Directv I can turn on and off but the channels won't gel so I can watch The TV
Search Results
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code. ... All the steps you'll need to program your Rogers Remote to control all your home theatre devices. .... the Cable turns on and off and volume etc. but will not shut offthe tv. ..... I bought a Element Electronic Smart TV and have set it up.
    Support ' Element Electronics - Elementelectronics.com
    www.elementelectronics.com/support/
    Element ElectronicsA description for this result is not available because of this site's robots.txt - learn more.
    DIRECTV - Support: Your Remote Control
    www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
    DirecTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On until they ... Power Key - Your DIRECTV™ Remote can operate alternate devices.
    [PDF]Get to know your remote control Need more help ... - AT&T
Jan 31, 2016 | RCA Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
DTA remote: when bringing up tv guide menue, i can see it but cant use the numbers to scroll left, right, up, down-i dont see the remote help box
try using the volume control slide or the channel selection slide as they are normally the scrol controls
Nov 21, 2015 | Comcast XFINITY
Will my virgin hd tv remot control be able to oporate the volume through its own amp or will i need to adust the volume with the toshiba tv remote on the tv itself
The easiest way is just to set the TV Volume with its own remote at the maximum level you'd want it and then use your Virgin remote to adjust the volume as and when required.
Jun 05, 2011 | Toshiba Televison & Video
How to setup Toshiba CT824 tv with digibox (I have no user manual)
You can connect the digibox (digital converter box) or DTA to the TV using coax jumpers and tuning the TV set to channel 3 or 4 in some cases.
Connect the input (wire from the wall or floor) to the input on the digital box.
Connect the output of the digital box to the input of the TV set.
Turn on TV and digital box, tune TV to channel 3 using the TV remote or the buttons on the TV itself.
Use the digital box remote to change channels. You may need a code to program the remote to work the TV set.
I hope this helped.
Cheers!
Apr 27, 2010 | Televison & Video
Comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Jan 10, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Iriver e 10
how to use the remote control.
1. go down to settings
2. remote control
3. find your tv brand (mines in ect(more brands))
4. point at tv (when on)
5. Scroll down list of numbers (#00; #01; ect)
6.go down to the bottom and if your tv dosn't turn off your tv isnt supported.
7. If it is supported click on the number your tv was
8. go back to the main menu
9. put it on hold (switch on side)
10. your done!
controls are:
up - channel up
down - channel down
left - volume down
right - volume up
power - off/on
smart key - mute
vol up - volume up
vol dwn - volume down
Jan 19, 2008 | iRiver E10 Digital Media Player
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
