Question about Refrigerators
Need to replace the gasket and flap of door ice dispenser for GE Refrigerator model GSS25JFPA WW
The gasket on the flap of the ice dispenser unit on the door has warped and allows air/humidity into the ice maker dispenser chamber and causes ice to bind together into a block that cannot fit through dispenser and has broken the plastic screw that pushes the ice out through the door dispenser. Need to remove door dispensing unit to replace gasket/flap. Don't know how to take apart.
  • 58 Answers
SOURCE: GE Refrigerator
first, let us explore the problem with dispenser flap. open the freezer and look into the ice discharge chute. there may be an accumilation of ice impeding the proper operation of the flap. next, you have indicated the light socket is broken. is it just the bulb or the socket itself? if you wish to remove the ice/water panel, first unplug the unit,. then you may be able to unsnap the drip tray where one would sit their water glass. if you are successful in doing this then the panel can be removed with a star driver but it depends upon the fasteners used. Always keep in mind to disconnect power before working on unit. I hope this was helpful.
Posted on Sep 26, 2008
  • 1122 Answers
SOURCE: Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Posted on Apr 14, 2009
SOURCE: GE ICE MAKER GSS25JFPA WW NOT MAKING ICE
could be a clogged water filter, bad ice maker or valve(s)
Posted on Apr 07, 2010
ZJLimited
  • 17970 Answers
SOURCE: Have a gs201eta ww refrigerator
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Posted on Jul 07, 2010
Sea Breeze
  • 4655 Answers
SOURCE: I have a Kenmore Elite
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
Posted on May 05, 2011
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
Hope helps.
Jul 07, 2010 | Refrigerators
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE mod #gsh22kgmb ww. port thru which ice exits
Try cleaning the edges of the flap and the ice chute as well. Once you've done that, check to see if the pivot rod is fully engaged at end side, as having it out of position could be causing it to "hang up" and not fully close.
If the rod has been knocked out of position, reposition it with your hands then you can lightly lube each end at the pivot points, with a food grade silicon lubricating spray. Use ONLY a food grade lubricant so you don't end up getting nasty tasting ice cubes or contaminating the cubes as they pass thru the chute and flap.
If that doesn't resolve the problem, you'll need to remove the chute & flap assembly from the dispenser section of the door and check for the return spring engagement, as it may have become disconnected and as a result, isn't closing the flap fully, as it should.
To do this, you'll need to remove the trim bezel around the dispenser section with a plastic putty knive (to avoid scratching the trim). be very careful when prying the bezel, do it VERY carefully so as not to snap/break the trim piece. Once you have that removed, you can see and get at the retaining screw(s) that hold the chute & flap assembly on the door panel.
Check the line drawing attached for proper part placement of the spring (part #63) and for seeing how your particular dispenser is attached to the freezer door.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GSH22KGMBWW&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-M-SERIES&diagramPageId=00004&componentDescription=FREEZER%20DOOR&documentId=G0311032&backToLink=Return%20to%20Sub%20Components%20list#partLst
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Refrigerators
GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer side has icing problem
check to see if the flap for the ice maker is open and or in need of cleaning, also look at the gaskets on the unit. Put vaseline on them if they feel brittle and it wilkl rejuvinate them.
Feb 01, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
