Question about Nokia 6260 Handheld
Asembling i want disassembly assembly video clip
  • aligator6260 Feb 27, 2009
    please! the assembley instructions/movie tu assemble the top part with the lower part on 6260! i can't fit the hinge:((
  • 91 Answers
I cant give you a video, but this might help you : http://www.uselessinfo.pwp.blueyonder.co.uk/dismantle6260.htm
Posted on Oct 08, 2007
I want disassembly assembly video clip
Posted on Nov 19, 2008
SOURCE:
Ingersoll Rand model 2135. Gun still runs with the trigger off. Disassembled, but cannot figure how to remove throttle assembly.
The throttle valve is housed inside the inlet bushing assembly (item# 26). To remove the assembly there are 2 slots near the bottom of the handle, you will see a metal tip through the slot, that is the clip (item# 27) that need to be depressed in order to remove the inlet bushing assembly (item# 26). There is a special tool to depress the clip but can be substituted by using a small flat head screw driver, once the clip is released, slide the assembly out of the housing and at the very top is the throttle valve (item# 28D) it is held in by a retaining ring (item# 28G). WARNING the throttle valve (item# 28D) has a spring (item# 28C) below pushing up, be careful when removing the retaining ring (item# 28G) it could pop out with some force!
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
Nov 24, 2013 | Air Tools & Compressors
How to remove headlight asembly on 2000 grand am
There is a black plastic cover under the hood, and right above the headlight. (A pain to remove, but necessary. Held on with black plastic button type fasteners.) Under the plastic, There are 2 metal tabs, (1 on either side.) These are supposed to be "easy" release clips lol. Pull them up, and the headlight assembly can come out the front of the car. Replace the bulb, and reverse procedure to reinstall.
Good luck and thank you for using Fixya
Mar 15, 2010 | 2000 Pontiac Grand Am GT
How to replace the front parking light bulb
There are two small screws holding a plastic cover on top of the head light assembly. Take that cover off and there are two sliding clips on the back of the headlight asembly. pull those up and the whole assm will come out. They are kinda tricky to line back up when you re-assemble, but it's not too bad of a job.
Feb 10, 2010 | 2003 Ford Ranger Regular Cab
Need to replace rear brake light on a 1999 Buick Park Avenue. How do I remove the plastic lenses or assembly?
you will need to open the trunk and remove the carpet covering the inside where the tail lights are, find 2 or 3 nuts which are probably 8 or 10 mm,so use a socket and ratchet,remove the nuts and pull the tail light asembly out from the back and you will find the tail light bulb sockets. release the little latch/lock clips while turning the socket assembly about 1/4 turn counter clockwise and you can check each bulb. watch where the wire harness for each socket and also the tail light assembly is so you dont pinch or damage the wires when putting the tail light assembly back in. your owners manual may also give you these instructions and will tell you the correct bulbs to use for tail, brake and turn signal lights.
Oct 27, 2009 | 1999 Buick Park Avenue
Blowing fuses on the lidswitch asembly so I replaced
the one screw that holds the asembly lousen it and slide it back and forth also make sure the lid switch acturater is in place properley u should be able to hear it click as u raise and lower the lid.hope this helps dont lousen that screw to much haundi24
Oct 26, 2009 | Maytag 22 Cycles Topload washer, SAV365Z
Need asembly instruction for workmate wm550
If you are in Australia get in touch with Bunnings and they should be able to either help you or point you in the right direction. Failing that see if you know the maker then look up their website just use theirname.com
Good Luck
Sep 07, 2009 | Hand Tools
Headlight assembly instructions
Should be as follows, First remove the plastic cover that goes from one side to the other. It has like 10 pop clips in it. Easiest way to get these out is to take a pair of end nippers and pull the center out then pull out the piece left there. This will make sure they are reusable. After thats out then there are two bolts, I think they are 12mm if I remimber right, They hold the headlight asembly in. After they are out then just give the assembly a good pop and release the metal clip that holds the bottom side of the assembly and the whole thing pops right out. Then twist and remove the bulb and your set to put the new one in in reverse order of course.
Mar 19, 2009 | 2001 Chevrolet Cavalier
How to dismantle samsung-e630
Visual aids for this specific model are not available online , but you can get the service manual for about $3 : Samsung E630 Service Manual: ASSEMBLY, DISASSEMBLY, REPAIR -
You can also refer to disassembly instructions for similar Samsung models:
d500 assemble disassemble part1
Samsung SGH-D500 Disassembly-Assembly Video
Mar 16, 2009 | Samsung SGH-E630 Cellular Phone
Nokia 6260 Handheld Logo
162 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
