Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
My dyson DS20 ANIMAL WONT WORK,WHAT COULD BE THE PROBLE?
Samyfam
  • 379 Answers
SOURCE: Dysons animal overheats and turns off What do we
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay2_bing.gif for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Posted on Mar 26, 2010
VacuumRepair
  • 438 Answers
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Posted on Apr 04, 2010
  • 53 Answers
SOURCE: dyson dc17 animal stopped sucking. brush still
Make sure the flexible hose that connects the beater brush housing up to the connection up by the dust bin is still connected. It could also have a hole in it so check for that as well.
Posted on May 31, 2010
  • 10865 Answers
SOURCE: dyson animal not sucking. Have cleaned out all
I had this problem with my DC07 and found the top of the cyclone was stuffed full of compacted dust.
You can (should be able to ) see all way to the top if you look up through the bottom of the center column. If ther's a load of dust up there, you should be able to dislodge a lot with a cane and a good shake.
I actually got to the point where I had nothing to loose, so I actually took the very top plate off the cyclone (3 or 4 Torx screws) and saw a huge plug of dust.
Do please note: Getting the top off and back on again is a **real bugg*r** because of the unlatching mechanism.
Having proved that Dysons **do** clog, I phoned Dyson and got hold of someone technical.
I described as briefly and concisely as I could the problem - top of the cyclone full of dust - and pointed (politely) out that Dyson's advertising stated clearly the machine was supposed never to clog. Ever.
I made no attempt to disguise the fact that my vacuum was out of warranty.
Dyson simply sent me a new cyclone and dust can free of charge!!!
Posted on Jul 28, 2010
DysonInfo
  • 107 Answers
You change the filters. You can find out more here: Looking after your Dyson
Posted on Nov 30, 2010
I have lost the top to the filter on my Dyson, DC59 GT9-US-FJC3318A. Will you help me get another?
Variant Parts - Dyson
https://www.dyson.com/parts/variant-parts.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Dyson parts for DC59 Animal. Carbon fiber brush bar $22.99 Replacement Carbon fiber brush bar assembly for your Dyson DC59 vacuum cleaner.
Dyson Vacuum and Fan Replacement Parts - Official Site ' Dyson.com
www.dyson.com/parts/select-variant.aspx?category=Cordless
  1. Cached
Find spares and replacement parts for your Dyson vacuum or fan. Select your machine model to see a full ... Dyson Hard DC56. Dyson DC59 Cordless Vacuum ...
Spare parts for DC59 Animal - Dyson
https://www.dyson.co.uk/spares/variant-spares.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Image of Soleplate rollers Soleplate roller pack £1.50 · Image of Wand assembly Wand £55.00 · Image of Crevice tool Crevice tool £10.00 · Dyson Combination ...
Dyson DC59 / DC62 Animal Vacuum Cleaner Parts
www.partswarehouse.com/Dyson-DC59-DC62-Animal-Cordless...s/6871.htm
  1. Cached
  2. Similar
Dyson DC59 / DC62 Animal Cordless Vacuum Parts, Accessories, & Repair Schematics. Free Shipping Available - PartsWarehouse.
Genuine Parts and Accessories for the DC59 Dyson Cordless Vacuum ...
https://www.dysonspares.ie/index.php?route=product/category&path=66_285
  1. Cached
Genuine Parts and Accessories for the Dyson DC59 range of Cordless Vacuum Cleaner. owerful handheld vacuum which boasts a brushless switched reluctance motor. It is small, light and powerful. Dyson DC59 Google Search
Dec 26, 2016 | Top Vacuums
How to fix D1 dyson animal wont suck
Hi there, it's Jack at Dyson.
I'm not sure from the information you've provided exactly which model of Dyson Animal vacuum you own. However if it's not picking up as well as it should be, it's likely there's a blockage somewhere in the machine, and the filter(s) may also need a wash.
For help getting your vacuum up and running again, please visit www.dyson.com and click 'Support'. You'll then be able to identify your machine from the list and access a selection of illustrated troubleshooting guides to walk you through resolving the issue.
Alternatively you're welcome to contact our experts directly for assistance if you'd prefer. You can reach us by calling the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 19, 2014 | Dyson Vacuums
Brush wont turn on my dyson....only had for 4 months....what do I do with this piece of crap?!?!
I agree. My store stopped selling Dyson 8 years ago. Before you toss it out, take it to your local vac shop for diagnosis. They can repair it or take it on trade for a quality vacuum cleaner.
Aug 07, 2017 | Dyson DC39 Animal Canister Vacuum
Problems with Dyson DC14 Animal Bagless Vacuum very little suction coming from the hose. cleaned filter and suction has not improved. Please help. Thanks
Two possible solutions come to mind. First off, there is a clog in your hose. If you have another vacuum, try using the hose on that one to **** it out.
If that doesn't work, you may need to have the clutch replaced. Check your warranty. The clog wont be covered, but the clutch will be,
Oct 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Animal on button wont stay on.
That's the problem with dyson. They work for the first few months then start to break down. Your switch might need replacing or your cord connection is lose and causing it to short out and turn off.
Aug 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc17 animal
on the bottom plate are 3 spots, one in the center and one at each corner, that need a flat head screw driver to loosen. turn left to unlock, this will remove the plate so you can clear the debris from the brush.
Feb 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush / roller wont turn
most likely the belt is broken. Bad news regarding all Dyson's. You can't replace just the belt your self. You have to purchase a new belt assembly which includes the gears. And it wont be cheap. I would call it a design flaw but i am sure that dyson calls it a profit scheme.
Nov 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
