Question about Jolees Easy Image Transfer Sheet -Light 10/Pkg-
When I pealed the backing it stuck and pulled the transfer off the shirt. Is my iron not hot enough?
Can i transfer my designs on a t-shirt with the print shop 2?
Any image can be added to a T shirt. You can buy specific paper which you print reverse on and then iron or take the image to a local T shirt shop. I used to run one and we would charge around 15 pounds including the clothing. Full colour upto A3 is the norm
Jun 06, 2012 | Software MacKiev Print Shop 2.0
I just melted my husbands shirt to my iron!!!!!!!!!! how do i clean this mess off of my iron???
Hi hahn rhonda...
Put your iron in the freezer and then use a scraper to scrap off the shirt when it is frozen.
If that does not work, the reheat your iron to the highest setting, after your iron is hot you can use an old cotton towel to iron backwards on to remove the shirt debris
Please take time to rate me
Aug 11, 2011 | Irons
I pressed a T-Shirt with old transfer material on it and the transfer is now on my top heating plate of my Singer Presser. How do I get it off without damaging my heating plate? I tried to press an old...
aplicar detergente multiuso no Brasil marca Veja Unilever associado a creme com abrasivo, tipo utilizado por mecanicos para retirada de graxa das mãos, pequena quantidade tomando cuidado com os furos do vapor. atenciosamente. @valefelix
Aug 08, 2011 | Singer Electronic Steam Press Iron
Fleece shirt melted on the bottom of non-stick iron
well try heating the iron and rub the wax on the heated iron and wipe it off using cotton cloth
Jan 04, 2010 | Sunbeam 4237 / 4238 Iron with Auto...
My rowenta leaks hot water
It is probably calsified (boiler stone has formed inside the steam ducts). Clean the iron according to the instruction manual.
If you have no manual, do this:
Heat the iron to the maximum in upright position with reservoir full of water. Turn the iron to 'operating position' i.e. in normal ironing position horizontally over a sink or similar. Use the extra steam button to force steam thru the iron. When the iron cools down so that the steam is no longer strong and some water is clearly leaking out, place the iron into upright position again.
When the iron is fully hot again, repeat the steaming. Do this until you have no water left. Let the iron cool down, add water and repeat the procedure until the iron doesn't leak anymore.
You will see the boiler stone coming out like hard dandruff. You can pull out bigger pieces with tweezers or similar. But be careful since the iron is hot!
Hope this helps. I do this roughly every month or two to keep the iron from leaking on my shirts.
Nov 26, 2009 | Cars & Trucks
Any new tips on how to remove the label from the back of the transfer?
These are IRON ON transfers that you do just that.
I bought some and wondered exactly that question until I read the instructions a little more.
Heads up it can take quite a bit f heat to get the best results. I was afraid of burning the Teeshirt but they worked great.
Also take great care removing the backing when you have ironed it on as I nearly pulled it back off the t shirt in a couple of places. I just laid it flat and used a little more heat in the affected area.
Oct 10, 2009 | Avery Transfer, T-Shirt, Dark...
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
Jolees Easy Image Transfer Sheet -Light 10/Pkg- Logo
380 people viewed this question
Top Jolees Photography Experts
Tony
Are you a Jolees Photography Expert? Answer questions, earn points and help others
