Question about Weber Baby Q Grill
Weber Model #396000 problem with flame.
For the first few seconds the flames is fine then acts like it is on low. Using the flame adjustment nob has no effect. We have recently replaced the regulator/hose with no effect. Propane tank is full. We Would greatly appreciate any help you might be able to give us.
burzerko
  • 254 Answers
SOURCE: low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Posted on Jul 20, 2008
  • 11 Answers
SOURCE: Weber Seriel #QT0379827 MOdel #396000 Baby Weber
CALL WEBER! They'll get some information from you and then either help you fix the problem, replace the defective part or replace the grill. They've never failed to solve a problem I've had with a Weber Grill!
PFSmith
Posted on Nov 23, 2008
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
  • 4736 Answers
SOURCE: we converted our weber Q
Your RV Propane System works on a different pressure than your, gas grill. Reinstalling the regulator may correct the pressure difference. Then install a short pipe nipple into the regulator and install a shutoff valve. After the shutoff valve, reinstall your quick disconnect hose. from here on after, each time you connect the hose to the grill, be sure the shutoff valve is OFF before making the connection. Then open the shutoff valve very, very, slowly, so as not to lock up the regulator.
Hope this helped you. Please let me know. Happy Grilling!!
Posted on Jun 24, 2011
How do I adjust the flame on my Weber gas grill
turning the knob adjusts the flame intensity
it is not doing that and the flame is very low
low gas in the cylinder
regulator
blocked jet for the burner
Nov 19, 2017 | Weber Grilling
Why is my flame low and the others don't light
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jun 24, 2014 | Weber Spirit SP-310 Propane Grill
What color should the burner flame be
The burner flame should be blue.
If you have the spider air flow open to wide the flames will be yellow.
This means the gas flow has to much oxygen.
Typically the air vent should nearly closed.
You may not be able to remove all the yellow and have a few Yellow tips.
This is ok, just try to adjust were you have the last amount of yellow in the flames.
Hope this helps.
Jul 18, 2010 | Weber Genesis Silver B Grill
Low and intermittent flame of weber Q 220
You can try replacing the regulator to cure the gas flow problem, I believe the ignition is a piezo, if it does not click when you push it or turn it, it most likely needs to be replaced. If it still clicks, then there could be a bad wire or electrode.
Dec 22, 2009 | Weber Baby Q Grill
When ever we get a full 20 lb. tank of lp gas, our 3 burner weber grill has a very low flame and it goes out frequently with low heat until it runs for a long time, then it runs normal.
Hello.
It sounds like your regulator is not quite right. Try a different one, or just replace yours. New regulators are inexpensive, and are available at Lowe's/Ace/Similar.
Best regards (and happy grillin'), --W/D--
Aug 18, 2009 | Grilling
I just hooked up an LPG bottle and hose to my Weber Q, and when I light it, the flame is very weak. In fact, the flame extinguishes after about 10 seconds. I can't seem to get the proper flow of gas to...
if using the adapter hose for large tank weber has had problems with hose call weber and get new one or call bbq galore and ask for a 4ft. adapter hose 214-696-0030
Aug 10, 2009 | Weber Q Grill
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
May 18, 2009 | Weber Baby Q Grill
Weber Grill
check hose for leaks using sponge soapy water . check for pinched hose. possible plug inside hose.wire brush the flame area
Nov 09, 2008 | Weber Grilling
Low flame on 3 main burners. model GBC730W
Mike, I had this problem with my grill once or twice. Like most of us grilling men we turn the grill off at the tank trying to be safe. Sometimes, like in my case, I do not turn the nobs back to the off position. When returning to the grill the next day or week the first thing we do is turn the gas on leaving the nobs on, then lighting. Every time I do this my flame never gets full or does not reach full temp. To resolve this: turn everything off including the nobs, then turn the gas on, wait a minute or two. Turn the nobs to full and ignite. It should be at full flame then, adjust from there. I hope this is helpfull.
Sep 23, 2008 | Grilling
PFSmith
Aug 06, 2008 | Weber Baby Q Grill
Weber Baby Q Grill Logo
108 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
