Question about Video Game Consoles & Games
Gamepad vmax
Driver
Logitech f130 was recognized before but now is not working?
You should delete all drivers of your gamepad and reinstall it again. Try this first.
If this doesnt help, try to make your gamepad work on another machine. If it works somewhere else, your computer is now the problem.
Mar 06, 2011 | Logitech Dual Action Gamepad...
How can i get my gamepad f310 to play online games?
Hi, welcome to FixYa!
I assume your gamepad is manufactured by Logitech, am I right? Have you installed the correct driver for the gamepad? If you haven't so, please install the correct driver for the gamepad, because your operating system will not able to use it before the driver get installed.
You can get the driver from here:
http://www.logitech.com/en-us/441/7360#section=downloads
Click on Download tab, and make sure you have choose the right operating system that you use.
I hope this can help.
Mar 06, 2011 | Computers & Internet
Gamepad drivers for win 7 64 bit
Try the gamepad official support website and download the driver or tell us your gamepad model for further support
Mar 03, 2011 | Computers & Internet
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
Vista driver for usb gamepad Gigatech
it's not compatible with vista.
Mar 05, 2009 | Computers & Internet
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
LOGITECH PRECISION USB GAMEPAD
It may sometimes work without drivers, but its recommended that you download the drivers and have them installed. That way you can also program the buttons for various functions if you want...
Cheers!
Apr 14, 2008 | Logitech Precision USB Gamepad PC Game...
Driver
see if this is what you need - http://drivers.softpedia.com/get/JOYSTICK-GAMEPAD-WHEELS-and-TABLETS/OTHERS/Gravis-Gamepad-Pro-10.shtml
Sep 20, 2007 | Gravis GamePad Pro Game Pad
Video Game Consoles & Games Logo
144 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
