Question about Maytag Microwave Ovens
Magic chef microwave mcc1010stg door won't open
The door will not open without pressing the release and tugging on the door
MicrowaveSvc
  • 9047 Answers
SOURCE: the door sticks on my microwave oven
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
Posted on Sep 15, 2006
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
  • 958 Answers
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Posted on Feb 11, 2008
  • 1335 Answers
SOURCE: Door will not open. Button release does not release the door latches.
The plastic lever release is more than likely broken. You can order the part from
http://www.repairclinic.com/Appliance-Parts?s=t-KCMS145JSS0-%3d%3dc226g5
It's about twenty dollars.
Posted on May 22, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
My magic chef microwave turns on when I shut the door and turns off when I open it
Check for a defective door switch (usually secondary switch) to see if it is functional.
Nov 23, 2016 | Magic Chef Microwave Ovens
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
Magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Nov 29, 2013 | Magic Chef 1-1 Cu Ft Microwave Oven -...
Magic Chef MCD1611ST Microwave Oven Door latch
1) see the diagram attached for to see the fuse, you must unplugged the power from the wall, and turn OFF the c.breaker from your house.
2) if the problem is the door latch see the video use the common sense.
God bless you
Sep 09, 2012 | Magic Chef MCD1611ST Microwave Oven
Blowing fuse when opening microwave door
the microwave has a short in the power supply it can be the diode or the high voltage capacitor.have a tech check your microwave for repairs.good luck.
Mar 01, 2010 | Magic Chef MCD1611 Microwave Oven
No heat on magic chef microwave
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
My Magic Chef Microwave is unresponsive and the display says "loc"
My magic chef is not working But when we open the door light is flash
Aug 12, 2009 | Magic Chef Microwave Ovens
Magic chef microwave model # mcc1010stg
You can download it here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
Dec 09, 2008 | Microwave Ovens
Microwave Ovens Logo
66 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
