Question about Refrigerators
How to change a ge model gts18dc freezer fan - Refrigerators
4 Suggested Answers
walterkunesk
  • 683 Answers
SOURCE: GE Profile Model PSB42LGRBWV Whistling noise
this noise you hear is the evaporator fan motor,
Posted on Feb 21, 2011
  • 932 Answers
SOURCE: GE refrigerator model GTS18DC. Freezer is as cold as it should be. The refrigerator isn't getting cold. What could this be? Thanks!
I would suggest using a hair dryer instead of chipping ice out of the way. You can damage the tubing way to easy and then you have big problems. It sounds like you are having a defrost issue and that could be your defrost timer, the defrost heating element, or the defrost thermostat. The heating element is usually the easiest part to check and all you need to check it is a meter that you can do a continuity check. Some of the newer refrigerators have the defrost timer on a circuit board now and you can only correct that possible problem by replacing the board. The thermostat can only be properly checked for continuity while it is below freezing temperature and then warm it up to see if you loose continuity. Hope this helps!
Posted on Apr 13, 2015
  • 488 Answers
Replacing Evaporator fan motor and main control board on ge side by side. Video.
Posted on Nov 26, 2015
I have a gts18dc Ge fridge and the freezer is too cold just replaced the evaporator fan motor
Hello:
What do you mean "Too cold"?.. normal operating temps are:
Freezer : -5 to 10 F,
Ref : 34 to 40 F
Jul 17, 2017 | GE Refrigerators
freezer blows cold air to fridge, sometimes freezer freezes at back and blocks holes for outlet to fridge, defrost and restart, or take back panel off freezer and chip clear
Apr 13, 2015 | GE Refrigerators
The temperature of my GE Model PSH23PGSD in freezer and refrigerator will not maintain 0 and 34
heat rises so if it's cold on the bottom and warm on top in freezer it sounds like you have a bad evap fan motor,when you open the freezer door do you hear the fan blowing,if not look around and hold the door switch in and see if it blows on some models fan won't run unless door is closed but if no fan you have a bad fan motor,the problem with ge is everything runs through the mother board located in the back,also i've found that the fan blade slides off or out of position on the shaft and it just doesn't move any air but you have to find out if it's the fan motor or the board,also the fridge should be set at 37 or 38 not 34,if your handy and you're going to fix this yourself,i would get both parts from repair clinic because you have 365 days to return parts,change the fan motor first if it sounds like the fan is your problem and see what happens,this way you have both parts and you can fix it that day and send back any part you don't need,if that's under 8 years i would change the fan motor,it's cheaper than the board if this is what's happening.hope this helps and good luck
Sep 29, 2017 | GE GBS18HBR Bottom Freezer Refrigerator
GE model GSS22SGRBSS freeser fan slows down
Same problem and think this unit is a piece of JUNK. In 5 years of service i have had to replace the Water shut off Valve twice, and the heater located on the bottom of the freezer which helps to keep the freezer defrosted. The fan has a whistling sound constantly, within 2 days of putting something in the freezer it is full of ice. Sorry pal, but as I said this model is a piece of junk.
Mar 15, 2010 | GE Refrigerators
GE Top Freezer Fridge - Freezer Buzzing
If you remove the half moon cap, and two 1/4" screws you can remove the cover and get to the fan. The fan motor shaft is mostly wobbling around making the buzzing sound.
Jun 28, 2009 | GE GTS22WCP Top Freezer Refrigerator
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan surges up and down
Don't worry, that is a variable speed DC fan motor. Fan speed is regulated by the mother board as needed.
Oct 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
