Question about Sewing Machines
Bernina bobbin race hook
I have a bernina 750. i got an error as i was doing embroidery. now I cannot get the bobbin out of the hook. any suggestions??
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
abhishek33
  • 1239 Answers
SOURCE: Have A bernina Activa 125
hi
you ended chat session and you dint rate it please rate it....here some suggestionMost likely cause is lint in and around bobbin area. If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Dec 08, 2008
  • 5 Answers
SOURCE: using a bernina gold latch bobbin case on the Bernina 435 machine
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Posted on Aug 15, 2009
  • 89 Answers
SOURCE: I have tried several steps to correct my Bernina
Buy to loose do you mean big loops on the botom? If so fallow these steps.
Usaly big loops on the botom of the fabric means that the top is not threaded coreccty. I would sugest threading the top thread again all the way to the needle. After you have done that pull on the thread and lift and lower the presser foot. There should be tension when it is down and no tensoin when it is up. I allway do this before I sew on a machine. If you do not have tension on it when the presser foot is down you did not get ithe thread in the tension unit. If you have tension when it is up then your machine needs a upper tension release adjustement.
Hope this helps friend.
Other problems could be a small peace of broke needle it the race area(inspect this close).
If you adjusted your bobbin tension this may need to be reset.
Posted on Mar 17, 2011
Testimonial: "Thank you! This did the trick! I thought the upper thread was correctly done but I did, indeed, miss the tension disk. LOVE this site!"
  • 166 Answers
SOURCE: I have a Bernina Artista 730. Very few inches of
It is likely that your bobbin sensor is either in need of a clean or is faulty. When you drop the bobbin door, the bobbin thread sensor is a black plastic 'box' on the inside of the bobbin door and attached to it. Look carefully and you will see a small lens and an opening next to it - these are the optical parts of the sensor - make sure there's no fluff or dust obscuring the optical parts - give it a brush with your fluff brish and clean the lens very gently with a cotton-bud. Dont use any chemicals or cleaners on this part. If the problem remains after this, the probability is that the sensor is faulty or the sensor connector cable is damaged. The cable runs the full length within the free-arm cover and up to the top of the front panel and I've come across a couple of similar machines where the service person has replaced the free-arm cover poorly and the cable has become trapped in the bottom drive mechanism. If cleaning fails to work, get your machine checked-out by a competent Bernina engineer. In the meantime, you can disable the error message, but dont just use this as a total solution.
Posted on Oct 17, 2011
I need the rotary hook only for a bernina 850 can anyone help me
Fixya does not sell rotary hooks and is not a buying service.
Nov 03, 2016 | Bernina Sewing Machines
After cleaning the bobbin sensor, error message keeps coming on. What else should I do?
You should probably take it to a Bernina repair person.
https://www.youtube.com/watch?v=RHYwvv8lJ74
http://sewsabina.com/blog/?p=84
http://freemo.com/bernina-artista-730e/
Jun 23, 2016 | Bernina Artista 640E Sewing, Quilting and...
Fix bobbin winder hub on bernina nova 900 sewing maching
are you talking about the bobbin winder spindle or the hook & hook race that holds the bobbin case?
Apr 02, 2012 | Bernina Sewing Machines
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
Hello, My bobbin thread was caught and as I was trying to get it out the hook system (I believe that is what it is) came out. How do I replace it?
You have a CB hook on your machine and this is very easy to remove and replace. In fact, you should remove the hook to clean the hook race and give it a drop of oil every few bobbins-worth of thread anyway, so if you're not doing that, your machine is probably trying to tell you something !!! I am assuming that the hook has simply dropped out of the mechanism and not that the whole hook and hook driver have come out, leaving a big hole in the hook race - if this has happened, you will need to replace the hook driver and its screw in the correct orientation, otherwise the machine timing will be out - if this is the case, you may be able to do the job yourself - contact me. Assuming it's just the hook, first-off, remove the bobbin/bobbin case from the central shaft on the hook. I am assuming the black plastic hook retainer has dropped-down and is laying on the bobbin door ... if not, you're in trouble !!! Rotate the handwheel on the machine until the needle is at the top of its travel. Look in the bobbin door at the hook race and you will see that the hook driver (a black plastic disc with a metal part curving round one edge) is positioned with the metal part on your left. Pick up the hook by the shaft and orientate it so that the metal is on the right - i.e. its a mirror to the hook driver. Carefully insert the hook into the hook race until it drops into the race itself and sits with the point downwards and a little bit of play between the hook and hook driver. It should stay there if there's a bit of oil in the hook race. You might like to use the opportunity to put one drop of Bernina oil into the hook race so that it flows into the groove that runs around the inside. Once the hook is sitting in the hook race, you only need to close the black plastic retainer onto it and press it until the lever on the left clicks into place firmly - that's probably why it dropped-out in the first place. Before putting the bobbin back in , just rotate the handwheel once to make sure nothing is binding - this will also distribute the oil if you've oiled it. Refit your bobbin/bobbin case, close the door and off you go.
Aug 13, 2011 | Bernina Virtuosa 160
How to oil? Where do you put oil?
The Activa range came with a lightweight plastic hook/shuttle that Bernina claims does not require oiling. Oiling/greasing of the main drive mechanism should only be done by a competent Bernina service engineer - it's not like the 'old' Berninas that had red paint spots next to all the oiling points ! I, however, always recommend that the hook/shuttle is removed every 3-5 bobbins-worth of thread and the hook race is thoroughly cleaned with a cotton-bud. Although Bernina says it doesn't need oil, I find that a small drop of oil on the hook race running surface is extremely beneficial to keeping the noise-level down and improving the consistency of the stitch formation.
Jul 18, 2011 | Bernina Activa 130
Im trying to put back my bobbin in a bernette 60 for bernina
The bobbin you just thread in the bobbin case and pop it back in with the tail pointing up. Now if you are talking about the hook and race cover I'll go over that aswell. The hook is the 1/2moon shaped part, put that in first, it goes opposite of the other 1/2 moon part already in there. Next put the round part over it(race cover). It goes on with the to demples to the inside and the flat part up. Then flit the tabs on the left and right over the race cover. Hope this helps
Mar 24, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Where is the shuttle race on a Bernina Artista 180? I'd like to be exact as to where to put the drop of oil.
Just to the left of the bobbin case you will see a small lever. Remove the bobbin case and push the lever and that will release the latch which holds the race cover and shuttle (hook).
Clean well with a toothbrush and place one small drop of oil on the edge of the hook where it makes contact with the raceway. Place the hook back and snap the race cover back on.
Oct 01, 2009 | Bernina Artista 180
Using a bernina gold latch bobbin case on the Bernina 435 machine
Apr 06, 2009 | Bernina Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
