Question about Sharp Televison & Video
Sharp lc26ad5ebk He lost his memory of the stored channels and not see anything, if you try to redo the tune is no longer found any channel
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
  • 121 Answers
SOURCE: how do I digitally tune my westinghouse TV SK32H24OS. Lost manua
The easiest way might be to unplug the power from the set for several minutes, plug it back in and then run through the setup procedure. You are specifically looking for the channel auto scan function.
Posted on Feb 25, 2009
emissionwiz
  • 76109 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
SOURCE: Channel selector does not work; can not auto tune
Sorry not be able to solve the problem. I have exactly the same problem. So it is not related to anything you've done. Something faulty in the TV. It happened after 1.5 years in my case. Any tech support link appreciated
Posted on Jan 12, 2010
One station only has lost sound but piture is great. All other channels work fine.
Have you tried retuning the TV? You may need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 09, 2014 | Hitachi Televison & Video
I re-tuned my TV (Samsung) on 03/09/14 as suggested by the pop-up message. i have now lost channels that are not listed as changing - namely Channel 24 (ITV4) and all the HD channels. i have tried the
You need to do a Full Factory Reset tuning rather than just a rescan.
Sep 07, 2014 | Samsung Televison & Video
Konka tv k1473pm
Do an auto-tune procedure. If not channels are stored with this process, make sure that the main system control memory IC to this set is faulty. Contact any service technician. Gopakumar Gopalan Google
Mar 02, 2014 | Televison & Video
The message "No stored channels found. Please run Auto Tuning
It sounds like the main system control memory IC to this set is faulty. Replace it.
Dec 13, 2013 | Samsung Televison & Video
Technika flat screen tv forgets digital channels found if switched to standby
Channel memory of stored channels is contained in a Eprom which may be part of the microprocessor------voltage when set is shut off is often from either the standby supply or even a filter cap that holds sufficient charge to maintain voltage for the memory.
Look in those areas first.
An alternate way would be to go to a box and input signal to rear audio and video jacks---the box would then retain channel memory etc and this would bypass your issue.
Apr 17, 2012 | Televison & Video
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
I now cant get bbc 1,2 ,3, on my free view box it wont tune in
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 12, 2009 | Televison & Video
No BBC channels available after retuning Sony Trinitron TV
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sharp Tv, can't tune in channels
Sounds like he accidently put it in parental lock, the remote should have the "key", the user instruction book will have the answer also. Hope this helps
Aug 16, 2007 | Sharp 14U-FM1 14" TV
Cant get local channels
If you can manually tune to the channels with no problem, then I would go in and add then into memory manually. If not then exchange the set as it might have a bad tuner or an AGC (automatic gain control) issue.
Apr 18, 2007 | Sharp 25H-M60 TV
Televison & Video Logo
13 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
