Question about Integra DTR 5.6 Multi Media Amp
DTR-5.6 I picked up a Integra DTR-5.6 with Output issues. The guy I purchased it from took it to a professional. He was told both Zone 1 and Zone 2 amps check out. The tech said it was a software problem. Zone 2 works in stereo. Any ideas on how to get this baby up and running? I couldn't pass it up at $20. Not bad, even if it is just stereo, but if I can get her going right and proper I'd like to. I'm putting together a Home Theater for my parents as a Christmas present. Any help would be appreciated. Thanks!
  • Garret Johnston
    Garret Johnston Nov 23, 2013
    I basically just need a flash jig and a copy of the firmware. Can anyone help with this? I can build the jig if someone could hook up a schematic. I found the jig for updating a 805. Is this the same jig?
5 Suggested Answers
  • 92 Answers
SOURCE: no output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
Posted on May 20, 2009
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
gopakumarg43
  • 75581 Answers
SOURCE: We hooked up our Integra
Hello
The DTR-5.2 contains an internal microcomputer that performs
high-level operations
Reset the device to its factory settings. Before doing that check the following 2 items.
[1] Input selector may not set properly.
Set to correct input source
[2] Headphones are connected.
Lower volume and then disconnect headphones
To reset it to factory settings:
To reset the surround mode and other settings to the factory
default settings, hold down the Preset Memory button with the
DTR-5.2 turned on and then press the Standby/On button.
"CLEAR" appears in the front display and the DTR-5.2 enters
the standby state.
If this also does not help; service is necessary to your set. Contact nearest Integra/Onkyo authorised service center. This is not any component fault. A service only necessary. OK.
Posted on Jun 26, 2011
AJIN G
  • 6694 Answers
SOURCE: my integra dtr 5.6 receiver
hi,
As you have mensioned it should be power supply problem. You have to check the voltage regulators at it power supply satge. it should need a good electronics servicing skill to find out the exact problem. if you are not experienced in it, then i will prefer you to consult some one more experience in it for such a costly system.
ok
Posted on Jul 30, 2011
How do I get into the network and firmware menu?
Try the following
Via Net
Is it reasonable to assume your router requires password / ssid to secure internet access ?
Due to age of this device,
(1) Lower / disable current router security settings
OR
(2) connect device directly to modem. ( softest, easiest way )
This may require you to disconnect modem from router, reset your modem then connect cable direct between modem and DTR 40.1 device.
When completed, the Modem ( and Router ) may need be reset, prior to re-connecting network
Firmware update information link ( from manual )
http://filedepot.onkyousa.com/Files/own_manuals/Firmware_Update_for_the_DTR50_1_40_1_DHC40_1_100110.pdf
Step 3:
Go to "7-6. Firmware Update" menu.
Note that the Firmware Update option will be grayed out
for 30 seconds after AV receiver/controller is turned on.
Please wait
( system attempts internet link for approximately 30 seconds ? )
Not outputting Sound ( trouble shooting ) link
http://www.integrahometheater.com/faqs_detail.cfm?detail=1&id=347
Hope this was helpful
May 12, 2014 | Integra Thx Dtr 40.1 Receiver
Integra receiver clicking
You most likely have a power amp problem, disconnect all speakers and see if still does the clicking, if so you have an output amp problem
Apr 01, 2014 | Integra DTR-5.1 Receiver
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
Onkyo integra dtr 6.8 protrection problems
The audio output stage has load issue, check speaker wires for shorts, if okay! the problem is in the semiconductors and this is where a professional is needed.
Apr 03, 2012 | Onkyo TX-SR605 Receiver
My Bush BTU160DTR comes up with black & white picture only. The TV works properly when disconnected from the DTR. How an I restore colour via the DTR?
If the DTR is set to S Video out then it will give a monochrome piscture as the colour content is not being picked up due to the TV Receiver.
Re set the DTR to Composite Video Output.
Dec 26, 2010 | Televison & Video
Jun 30, 2009 | Integra DTR-5.2 Receiver
No output to subwoofer per-amp
May 11, 2009 | Integra DTR-8.3 Receiver
Integra DTR 5.6 Multi Media Amp Logo
54 people viewed this question
Top Integra Audio Players & Recorders Experts
Rob Villi
Level 1 Expert
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
